![]() | Home > Maintenance & Mods (L322) > Rear brake line replacement - Any contacts? |
@ennoch - no idea if it’s an MOT fail but just worth checking before you do it is all I’m saying |
Ennoch Member Since: 26 Dec 2015 Location: Scotland Posts: 109 ![]() |
No worries @JayGee, I thought I was missing something on the MOT test. There's nothing in there they could fail on unless they're not secured correctly. And yes, they definitely need to be secured otherwise the clear heat shrink coating will wear through to the stainless braid which then acts like a cheesegrater, ironically more to the surrounding body and parts than the lines themselves. Rivnuts and p-clips or lots of zip ties will see it good. As long as you stop bits of it flapping about it will be fine as the hardline is only ever going to be used in a non-moving location. Is it the 'best' option if you're trying to keep factory/OEM? Absolutely not. If you could use hard line then I would. But for situations like the up and over the tank section I think it's a valid option to consider, especially as alternative routing for a new section of kunifer could easily introduce its own issues. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1473 ![]() ![]() |
I replaced my rears pipes with kunifer and if i remember correctly, I did it 2 sections. The first along the sill line run front to back, and the second sections going up and over the subframe to the flex pipes. That way I could manage the pipe lengths and the bends they would have had to do. You could see the pipe run across the top and i dont recall it being that hard to get the old one out and the new pipe slid in to run across. The garage that did the next MOT even commented it was decent enough that I could get a job with them doing it. |
Just to add to this, I thought I'd ping a mate of mine who is a tester and see what he said in case I was talking out my proverbial. As long as it's fully secured and not at risk of damaging anything or being damaged, there is no issue with using flexi for the brake line in places where it wasn't originally used. Hope that helps anyone considering this. |
@Ennoch |
j3fry Member Since: 23 Dec 2014 Location: Bedfordshire Posts: 59 ![]() ![]() ![]() |
Hi you do not need to drop the rear end to fit original brake lines as you can carefully feed the new pipe across the axle it’s a bit of a faff but is doable as I have done both of mine from front to back and if the person has a lift even better because the brake line that crosses the axle is very long but as I say it’s not an extremely hard job to do and it looks so much better with all the genuine bends |
