![]() | Home > Technical (L405) > L405 Completely Dead Battery This Morning |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 373 ![]() ![]() ![]() |
So I trundled out this morning, remote didn't work. I went off to get the spare one, but that didn't work either. I opened the car with the blade, no alarm, no ignition - just dead as a doornail.
So here's the update. When the battery is dead, you cant get in the boot to access the battery to charge it.
So the box with the big + on is actually on the left (looking from the front), and you can hook up a battery charger.
And as soon as you do, the horn starts blaring and the alarm goes off. The key fob (both) seems to have no effect, the boot won't open as yet, but the back and interior lights are on. Eventually, the alarm shut up, not sure yet if it responded to the fob or shut up on its own. I'll try and get some charge into it and see. 2017 4.4 SDV8 Autobiography in black 2018 D300 SE Velar in champagne 1982 Rolls Royce Silver Spirit in green Spiffing wheel centre caps, L322 sill repair panels, etc Last edited by Stuart- on 3rd Jul 2023 8:09pm. Edited 2 times in total |
Not yet. My inclination at the moment is to leave it overnight charging from the front posts. I found an earlier topic here that suggests that this method is OK.
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 197 ![]() ![]() ![]() |
I watched a utube video only the other day. They had power to a degree but a whole lot of warnings on the dash. It was an earth point under the driver wheel arch. Don’t know if this may be related 2016 4.4 diesel |
Interesting video, thanks. Someone might want to put that more accessible here, maybe in the Wiki. That will be of great use to many.
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1163 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic62384.html
I charged it overnight, it started fine this morning. No warning lights. I just put the voltmeter on it at work and it's showing its charging at 14.67v which seems fine.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8568 ![]() ![]() ![]() |
It could be a failing second battery, using those charge points under the bonnet does not charge the second battery, both batteries charge separately but back each other up when power is needed...
Popped along to the indy this afternoon, battery tested fine (he said the secondary one wouldn't cause this as it's only an auxiliary one). Plugged the computer in and it showed no faults.
It connects to the main battery when needed and if it's flat it will drag down the main battery...... It costs noting to check the voltage on it....! Pete
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35667 ![]() ![]() |
the aux battery [or capacitor if fitted] is mainly used to supplement the main battery in the stop/start situation..
