Home > Technical (L322) > sqeeeeky brakes and a knocking noise
E18RLY
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
i bought a l322 03 plate from a garage about half hour away from mine. seemed fine standard except a autobiogrphy badge Confused got it home and found the badge is super glued on theres wires for a sub and amp in the boot a window didnt work air susp inactve a knocking noise and squeeky brakes.
car went back 3 weeks ago and got a clio with 17s as a courtesy car Confused got the rangey back yesterday with sqeaky brakes and a knocking noise i wasnt impressed its had new front and back discs and pads thought they were bedding in but done 300 mile and still sqeaking and the knocking noise is from the front passenger side when i hit a bump the garage cannot find the problem and its just passed a mot any ideas please?
cheers scott
Post #66805 2nd Jun 2011 8:40pm
Squeeky brakes are down to the pads vibrating. It should go as the discs and pads bed in. A goad coating of copper grease on the back of the pads should stop the squeek. The knock could be suspension or drive related. Does it know when you put the car into drive? Does it knock going over bumps etc? What millage and is it a V8 or TD6?
Post #66812 2nd Jun 2011 9:02pm
E18RLY
its a td6 90k ill give the copper greese a try cheers what do you mean dose it know when its in drive?
it just sounds asif somethings loose
Post #66814 2nd Jun 2011 9:06pm
Sorry mate I'm on my iPhone and it likes to randomly change words. Lol. What I ment is does it make the noise when the cars in drive? Do you know about the well documented problems with the GM box in the TD6? The knock could be transmission related. If it is get it checked well inside the warrenty as a new box is the best part of £2k.
Post #66816 2nd Jun 2011 9:17pm
E18RLY
No I'm new to range rovers it's my first automatic I'm used to fiestas and civics It sounds more like a drop link or anti roll bar bush or something what's the problem with them and how do I tell if Iv got a problem? I'm working my way through the technicals on the site to build up knowledge.
Post #66821 2nd Jun 2011 9:44pm
A quick low down: the GM box (the one fitted to the TD6) was "filled for life" with fluid. This oil over time breaks down and if not changed can cause catastrophic failure of the box. As the TD6 is getting older not Hess problems are appearing more and more. GM have since reducedthe life of the oil to 60k miles I think to stop the failures due to fluid degradation. Faults range from knocking, slow to engage drive, juddering, rough gear change and big bangs. If you engage drive and don't get instant forward motion it could be he start of serious problems. People have had no drive for 5-10sec after selecting drive. Do a search for "transmission failure" and have a read. Your problems may not be linked but atleast you will be armed to know what to look for as this is the biggest problem the TD6 faces. There are loads of people here who will help in any way we can. Have paitence and I'm sure we will work through all your problems/issues
Rob
Post #66824 2nd Jun 2011 10:48pm
E18RLY
Had a little read through don't think this is my problem a think its a wishbone bush but cheers for the help I'm going to get my box oil changed next week.
Thanks again Very Happy
Post #67774 8th Jun 2011 8:29pm
