Home > Off Topic > Snow Foam Query |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7831 |
I know there is loads of info and videos on the net, but I have a pressure washer with a detergent bottle attachment and am thinking about getting some fairly cheap snow foam to try it. Prefer to get the views of those that have used it….
1st Jul 2023 9:46am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35427 |
is this any help Mark,
1st Jul 2023 9:50am |
Thanks Gents. Just what I needed to know.
1st Jul 2023 10:27am |
RDR Member Since: 05 Sep 2014 Location: Derbyshire Posts: 278 |
When I first tried it I thought it was rubbish I was expecting it to miraculously bring the car to a showroom shine with a rinse. Then I spoke to my valet guy he asked me to rub my hand over my 4 weeks dirty car and feel the roughness. Idea is as above if you can lift as much of that gritty dirt off before you start rubbing a sponge over it you reduce the prospect of paint damage. It also helps increases the life of ceramic coats etc.
1st Jul 2023 11:01am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
As everyone else has indicated, there is no magic "remove all dirt and grime" with snow foam, there is no replacement for a good contact wash.
1st Jul 2023 11:09am |
It’s fun and smells nice too MY23 PHEV HSE
1st Jul 2023 11:11am |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 907 |
I'm currently using cherry |
1st Jul 2023 2:46pm |
Ryanmt Member Since: 14 May 2015 Location: Warrington Posts: 72 |
I use it. I soak the car then leave it to fall and drag the dirt with it. Rinse the car then go at it with the mitt and a bucket of soapy water.
1st Jul 2023 5:33pm |
Ennoch Member Since: 26 Dec 2015 Location: Scotland Posts: 109 |
You can tell I have too much time on my hands...
1st Jul 2023 5:57pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Snowfoam does help, it sticks to the car and the dirt giving it time to gently lift the dirt from the body or soften it's attachment at least. It does need to be applied with a proper snowfoam attachment though, air is mixed with the solution to foam rather than just soapy water that the detergent bottle would do.
I spray it on with the snowfoam attachment, leave it for a while, rinse off, then shampoo in the normal way, whatever is your preferred method.
You should be caressing the bodywork of your beautiful lady One item I have found that makes a tremendous difference is Sams Detailing Ceramic Boost. https://www.samsdetailing.co.uk/collection...9069679685 Have a look at the video and it really does work as shown, the bodywork feels highly polished afterwards and it lasts a good 2 to 3 months. Watch the video (turn the sound off, the music is dreadful). BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
2nd Jul 2023 4:14am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 541 |
I usually snow foam mine, but not always. As others have said, it does work and is a good pre-wash, gets loads of grime off if the car is really dirty. One thing though, if you're thinking of using it in the pressure washer detergent bottle, I don't think it will foam, you need a proper foam lance. Drives:
2nd Jul 2023 6:33am |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1546 |
Well, as usual I ‘m at odds:
2nd Jul 2023 12:07pm |
The snow foam I have is called 'snow foam pre wash' https://www.jennychem.com/products/cherry-...10-1000ltr |
2nd Jul 2023 12:45pm |
Well I’ve ordered 10 litres of not too expensive snow foam, to see if I like the concept. I then looked at the instructions for the pressure washer I have to see it’s just a detergent additive bottle, for use on decking etc, not a foamer. I’ve thus ended up buying a snow foam lance, see how we go.
2nd Jul 2023 4:25pm |
