Home > Technical (L405) > Restricted performance P006A-00 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Take it to James Henshall at Henshall Engineering. Leave it with him. Don’t expect a quick turnaround as he’s a very busy guy. Why? Because he’s bloody good. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
27th Jun 2023 3:24pm |
If you were down south I’d recommend Glenrands but it’s a bit far for you maybe 😎🤭 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1130 |
How the hell can LR not find the fault? overfinch modified |
27th Jun 2023 3:56pm |
111Jay Member Since: 27 Jun 2023 Location: Manchester Posts: 4 |
Many thanks Rob, I’ll try and contact James tomorrow |
27th Jun 2023 4:12pm |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 351 |
How many times has it been smoke / pressure tested?
28th Jun 2023 8:02am |
That’s a very good point Andy. It’s always been cold when it’s been smoke tested.
28th Jun 2023 8:29am |
I've never worked on a tdv6 so not 100% what else there is thats plastic that you haven't already changed. Intercooler end tanks are probably plastic and buried behind the bumper so could be a hard spot when done cold, not sure if the v6 has the turbo changeover valve under the rad pack.
28th Jun 2023 12:40pm |
It literally came back last week after the a new changeover valve was fitted, and alas, no better, hence the post.
28th Jun 2023 6:25pm |
Don't rule out the pipework from the filters to the turbo either, if the V6 has twin filters then smoke both sides, a lot think because it's not pressurised then the fault won't be there or it won't matter but if it's holed then the turbo will suck in un metred air. so in effect you've got too much air than expected rather than a leak. Current
29th Jun 2023 8:33am |
