Home > My Range Rover > Towing Experience in L322 4.4TDV8 |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 192 |
So I had my very first experience doing proper towing today. I have a 750kg trailer that I’ve used a fair bit over the years and that’s no bother at all. However, today was my first proper tow where a B+E was required, and now I am legal thanks to recent change in legislation.
26th Jun 2023 8:04pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
The anti rattle clamp silenced our’s when we had one it was done up quite tight though! I also wouldn’t have described it as a rattle, but more a knock every now and again when going over dips in the road that caused the trailer to unweight a little. You could recreate the sound by hand by lifting and dropping the tow bar. Absolutely no vibrations back through the tow bar though and other than the knock every now and again it was silent / undetectable to the point you could easily forget you were towing!
26th Jun 2023 10:05pm |
Thanks both and useful info! From the image below, it appears that the end of the male receiver on the removable eggcup type hitch is different in shape and looks longer. I’m assuming it pushes up against some kind of bar further back in the receiver to create a snug fit that acts like an anti-rattle.
26th Jun 2023 10:31pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3108 |
Thinking about it now, I'm sure Land Rover had a TSB (technical service bulletin) back in the day for the farmers hitch rattling. If I'm remembering correctly, I believe they shimmed it to make it a more snug fit.
27th Jun 2023 10:28am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2494 |
I welded a bolt onto the end of my hitch on which I fit a plate large enough to cover the receiver then tighten the nut pulling the hitch forwards hard against the pin. The hitch doesn't move. |
27th Jun 2023 12:33pm |
JavaBlack Member Since: 07 Sep 2016 Location: UK Posts: 67 |
27th Jun 2023 12:36pm |
So a quick update as have been doing a bit more towing these last few weeks. Nothing as heavy as the rig that started this thread, but a nice double axle un-braked trailer that I use for household errands and gardening stuff. Anyway, it turns out the the anti-rattle clamp I was using doesn’t get a good purchase on the farmers hitch due to the design of a strengthening spline that runs underneath the long bar. In effect, it stops the clamp pulling it up taught. It’s hard to tell when wriggling it by hand but it’s no good. Anyway, I turned it the other way up to the photo here, so nuts on top, and it’s solved the rattle. It’s just the way the Westfalia armature and hitch are designed as there is also a lip around the receiver.
29th Jul 2023 10:04pm |
