Home > Technical (L322) > 2012 L322 dashboard vent replacement
dsm
Hi all,
I had my dashboard apart this weekend to fit the Unique Auto Apple Carplay adapter (which is great, btw).
[And no, my steering wheel isn't missing-in-action, it's a LHD model!]
I put (almost) everything back together successfully, but I can't get the top vent to go back in the dashboard! It is missing some metal clips, which is likely why it won't hold in, but I've tried wiggling it in all sorts of ways and can't get it to seat correctly. It looks like the front goes in first, then the back goes in on the three clips - but doing that means it isn't aligned with the vent outlets underneath. There are a couple of Torx screws under it that hold the dashboard in place, so I can't put it in the dashboard first. Is there knack to this?
Also I'm missing some trim fastenings, specifically the metal clips that go on the plastic bits (like on the central vent), and a load of black Torx screws. Does anybody know the best place to get these? The Torx screws are used everywhere around the dashboard so I assume they're a very common part I can buy in bags of a hundred, but eBay, Amazon and Google have come up blank.
Many thanks!
Post #667621 26th Jun 2023 4:13pm
BAZ8046
Hi,
These clips should work, I bought some similar clips for my 2012 last week and they fit fine.
Unfortunately the exact ones I bought are out of stock.
https://www.amazon.co.uk/AUTOHAUX-Dashboar...amp;sr=8-5
The top vent is difficult to refit, if it doesn’t line up with the duct it won’t go in.
It needs to go in fairly flat and using a torch through the gap helps to see.
Once it aligns it will slot straight in.
Hope this helps.
Post #667629 26th Jun 2023 5:39pm
dsm
Thank you! I'll try that...
Post #667661 26th Jun 2023 10:09pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
I too struggled with mine, and I just recall thinking "It doesn't go in the way you expect" it's not intuitive. I wish I could remember, but just try fitting one side first - even if you think it won't work or it's wrong. The obvious way doesn't work. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #667691 27th Jun 2023 11:15am
