Home > In Car Electronics (L405) > Audio/Video Greyed out
rdp1988
Hi all
Audio/video greyed out for a week now. It has done this before and worked half an hour later.
The only thing this time was that I drove through a thunderstorm the day before it stopped working so possible water damage somewhere? Trying to avoid putting it into a mechanic if I can diagnose myself but wouldn't have a clue where to start.
Post #667439 24th Jun 2023 12:18pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
A lot of your audio equipment, Amplifier ETC is under the passenger seat and also the lowest point so if water has got in thats where it goes, the sunroof drain could be the culprit if water has got in, they are not unknown for the pipe corroding then leaking water in the car instead of draining it away, only a wild guess though, you may not have a pan roof that opens.
Post #667490 25th Jun 2023 8:45am
ahrrov
2014 Range Rover Autobiography TDV6 Loire Blue
Hi, did you find a solution to the problem? This exact same thing has happened to me only yesterday. Gutted..
Post #669642 23rd Jul 2023 1:58pm
rdp1988
I’m leaving the car with a mechanic (family friend) today so will let you know the outcome.
I’ve read online it could be a simple software upgrade or a replacement amplifier. Let’s hope it’s the former!
Post #669682 24th Jul 2023 9:11am
ahrrov
That would be great thanks, fingers crossed for you..
Post #669729 24th Jul 2023 5:27pm
