Home > Technical (L322) > Restricted performance inlet manifold split. |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3141 |
I had it done as it needs the injector loom replacing etc. cost was £1600 all in. You can see the bill and part numbers used etc here.
23rd Jun 2023 7:22pm |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 |
I did it on my 3.6 tdv8 and even though it’s a different engine- it was an absolute pig to do, the injectors nearest the bull head won’t clear the chassis so you have to raise the engine to get them out- and good luck with the drivers side one!! 2009 (2010 MY) 5.0 Supercharged Autobiography
23rd Jun 2023 10:11pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Its much easier on a 4.4 TDV8... Takes me 30-45 mins but I have done a load of them... Easy home mechanic job sir... The blue silicone hoses show they have been changed before... |
23rd Jun 2023 11:53pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
RRV78, this looks like the 4.4 TDV8 and not the 4.4 BMW Petrol V8?
24th Jun 2023 7:51am |
Think you are talking about an inlet manifold replacement on a 3.6 here sir… The OP has a later 4.4 TDV8 and is after just the inlet pipes sir… |
24th Jun 2023 8:33am |
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 |
Hi Craig
24th Jun 2023 9:42am |
Ahh my apologies sir… thought it was the silicone that had split…
24th Jun 2023 1:41pm |
That’s ok. So you wouldn’t recommend taking on a manifold swap myself then? Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
24th Jun 2023 2:16pm |
[/quote] Think you are talking about an inlet manifold replacement on a 3.6 here sir… The OP has a later 4.4 TDV8 and is after just the inlet pipes sir…[/quote]
24th Jun 2023 6:09pm |
Yes yes, we’ve worked that much out now sir… 👍 |
24th Jun 2023 6:45pm |
No my friend… Not unless you’re really brave! The injectors can be a complete to remove & refit! If you do feel confident? By all means crack on but, don’t go into it blind! Get some research done beforehand sir… |
24th Jun 2023 6:48pm |
Thanks for the reply Craig as it is the inlet manifold that seems to of split at the seems I’ll be looking for a good independent in my area to undertake the job I think!
24th Jun 2023 10:30pm |
Apologies, I was looking and thinking it's the donut then remembered the ports are on the inlet manifold, not the intake manifold as you say.
25th Jun 2023 7:59am |
