Don't take this as gospel but I did read a thread a while back where there was an air leak at one corner and when the cars electronics systems periodically wake up, it detects the height difference and levels the car so all four corners match.
It could also be that you have a leak in the system and if both valve blocks are not holding a good seal, then air will leak from the complete system thus levelling the car at all four corners.
Control module fault ? Also when the car is back to normal ride height, check all four height sensors are reading the same in case this is a cause, probably not but, but it is a simple check to carry out.
I would think that carrying 200Kg recently is just a coincidence considering what these will carry of tow.
Does the car level out relatively quickly and stay there once you start the car ? I would start by listening and checking for leaks first, easy and cheap to do. Hope this helps
