Home > Technical (L405) > Won't start- immobiliser not playing
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
Just got in this morning, at a hotel miles from anywhere and the ghost won't disarm. I've tried the emergency bypass code, ghost suggest the battery may be low. I've plugged on my noco booster but still no joy. Any suggestions as I'm 100 miles from home and due to go on a weekend trip with friends in the car tonight. Help!? First time FFRR owner
Post #667296 22nd Jun 2023 11:19am
Kot
So if it is not the battery!
On the Black card item C!
Try using the full beam switch instead of accelerator button when inputting your emergency code
and complete D and E accordingly for each digit of the code 2018 SE SDV8 4.4 Byron Blue
Post #667315 22nd Jun 2023 5:18pm
Kot
Do you have the manual with you?
Page 9
"on certain vehicles accelerator pedal is not possible to read on CAN data network"
Also instead of accelerator pedal, hazard warning button may be used, it depends what your installer noted on your documents. 2018 SE SDV8 4.4 Byron Blue
Post #667316 22nd Jun 2023 5:28pm
caymanblack
Surely Ghost should be able to tell him all this? It could be the battery is not good enough. overfinch modified
Post #667317 22nd Jun 2023 6:14pm
Arch Stanton
Update, yesterday was mega tight on time I was in penrith and needed to be on the south coast with friends, in the car in the evening.
Ghost were called and after plenty of mithering, an angineer arrived from Liverpool. 10 minutes fter the engineer landed, I was up and running, a poor solder joint had broke.
Great service from ghost and their engineer. First time FFRR owner
Post #667344 23rd Jun 2023 9:31am
caymanblack
Great result , pleased to hear. Thumbs Up overfinch modified
Post #667350 23rd Jun 2023 10:03am
Arch Stanton
1 weekend and 600 miles later, the car ran great, immobiliser worked as it should.
There was a touch of anxiety every time I turned the car on though...
Great service from Ghost, chatted to the engineer about car theft while he was working, hopefully all the shizzle on mine will make it safe. (fingers crossed) First time FFRR owner
Post #667546 25th Jun 2023 8:25pm
