Home > Technical (L405) > Remove centre console to access the gear selector unit |
PhillV8s Member Since: 03 Jun 2022 Location: Worcestershire Posts: 44 |
Does this help?
27th May 2023 4:54pm |
Crasher242 Member Since: 07 Mar 2019 Location: Warwickshire Posts: 135 |
Other than the language that does indeed provide a good view on how to get at it
27th May 2023 7:23pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1194 |
I agree it is informative don't need the language to understand what to do. 2017 SDV8 4.4 silicon silver AB
28th May 2023 7:25am |
So I thought I would come back to this to report on my bank holiday Monday efforts to rip the interior of my car apart
30th May 2023 11:30am |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 295 |
Hi mine has just decided to pack up also gear selector rises but stuck in park just to add more spice to it the recalibrate EPB yellow light is on and off also!! fault code on IID
31st May 2023 7:39am |
I'd say it took me a good 5-6 hours in total to extract it from the vehicle. Mind you, i was following the video linked by PillV8s and had to keep going back and forth over some of the bits just to make sure i was doing it correctly.
31st May 2023 10:32am |
Cheers for this yeah I seen a few companies offering refurb local Steelers have them in stock at £750 just shopping around now for prices.
31st May 2023 11:23am |
I thought I would circle back to this to provide a happy update.
8th Jun 2023 10:21am |
Hi mate going attempt this at weekend you say whole centre console had to be moved back doesn't show this in video they just undo the screws near the top and able the top console open and hold it up with a screw driver. Did you take off the console under the temperature dials it doesn't show how to do this in video.
22nd Jun 2023 9:21am |
Hi
22nd Jun 2023 9:29am |
Hi yes I have already removed a few bits the temp control panel silver side trims panel that surrounds the touch screen I was refering to just below the temp control panel the centre console goes right under neath it but the video skips the removal of this was it straightforward to remove just Torx screws etc.
22nd Jun 2023 9:41am |
