Home > Maintenance & Mods (L322) > Windscreen Replacement
madnessgonemad
Morning all.
National Windscreens are coming today to replace my screen. I’m obviously going to keep a careful eye on them as I am at home but is there anything in particular I should watch for?
Thanks
Post #667192 21st Jun 2023 7:34am
They may have trouble removing the wipers and try to fit the screen with them and the plastic scuttle in place, this is not a good idea...!!
If/when they do get it off check the clips on the plastic scuttle, if even one is missing or broken it won't fit properly and will whistle at speed.... I have seen them glue the scuttle back on to try to prevent this but it's a bodge...
They broke some clips off mine and when I mentioned it they replaced the whole scuttle, it is hundreds of £'s so check it well.... Pete
Post #667197 21st Jun 2023 8:01am
madnessgonemad
Thank you. I will insist that the wipers come off.
How does the plastic surround come off? Do you just pull it off?
Post #667213 21st Jun 2023 9:16am
A bit late but yes, just pulls off, after removing the few trim clips, then there are other clips behind it and it's these that tend to break....
Hope it went OK.. Pete
Post #667251 21st Jun 2023 5:36pm
madnessgonemad
Thank you. I think I’m going to end up buying some clips.
In fact they didn’t come. Cancelled this morning due to staff sickness. Very annoying as I had left the afternoon clear. Coming ? next Friday now
Post #667255 21st Jun 2023 6:00pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Unfortunately the clips that break are part of the scuttle panel so can't be bought independently of it. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #667262 21st Jun 2023 6:47pm
Yep, as Dan says the other clips are the actual scuttle itself...
It's many hundreds of pounds so make sure all the parts that clip in are present or it WILL annoy the hell out of you on a motorway at speed, especially in crosswinds.... Thumbs Up
Another issue is the rain sensor, it has to be positioned correctly and fitted to the new screen without any bubbles, most fitters are experienced in the now but make sure you try it with a hose on spray after the screen has cured and is OK to get wet... Pete
Post #667263 21st Jun 2023 7:09pm
