![]() | Home > Maintenance & Mods (L322) > P0401-00 EGR Flow Insufficient - what to do? |
Ajmngn Member Since: 25 May 2021 Location: Cambridgeshire Posts: 210 ![]() ![]() ![]() |
JayGee, thanks for the tip on the other thread ref the MAPT sensor reading 14.5psi when engine off. I was thinking the same thing about sensor error as that appears to be my most likely culprit. I now need to investigate the Temp bit and see how the EGR outlet temp sensor and the T bit of the MAPT sensor correlate.
Wow!! That’s incredible, and thank you for taking the time to find that photo. If that’s not a 4.4TDV8 cooler then it’s basically the same design so equally applicable. I’m optimistic mine isn’t that bad as have been running the car for a year since new EGR valve and not had any problems until last month, so hopefully I’ve caught it before it gets anywhere near that bad. Also I don’t want to make accusations without any proof so I choose my words carefully and phrase this in a positive light to give them the benefit of doubt…Glenrands (site sponsor) changed my EGR valve a year ago; they have a fantastic reputation and my own personal experience of work with them on 3 occasions reflects the general consensus and I would recommend them to others; so, if they took my EGR valve off to change it, saw that and didn’t do anything about it before putting the assembly back together, then they don’t deserve the reputation that they have built or any further custom from members of this forum. I would like to think they at least attempted a simple clean but maybe they weren’t able to give it the time that you or I would’ve if you had it in your hands and knew it was a 4 hour job to get it back out again in the future! Anyway, as you can see above, I’ve got 1L in the cooler now and will leave it overnight before extracting in the morning. Fingers crossed it at least does something good. All I can do is cross my fingers and hope, whilst you lot all laugh at me for being this forum’s crazy Guinea pig who goes through with his experimental ideas!! Andy 2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior 2017 Audi SQ5 3.0 V6T Quattro in Volcano Red 2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green (Currently SORN whilst undergoing some serious restoration!) |
Nope, no RP. All that happens is the ECU obviously detects restricted flow, so the default setting when that happens is to shut down the EGR valve motor so the mechanical sprung valve just closes itself and no exhaust gas through into the plenum at all. It’s like a free EGR delete but without having to pay for the privilege. I just don’t want it to get worse and worse so I end up with even more problems. I say no harm in giving cleaning a go as it’s not difficult to do what I’ve described, and the fluid was only £20 for 5 litres.
Update 3
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3384 ![]() ![]() ![]() |
Great result - hope it stays clean now. 2012 TDV8 Vogue (L322) |
Update 4
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4350 ![]() ![]() ![]() |
Have a chat to these guys as an option: www.rangeroverworld.co.uk
Update 5
Update 6
Update 7
Glad to hear it's behaving itself! Great technical write up for future reference too |
Nice result Andy and a valuable addition to the collective knowledge base |
