![]() | Home > Maintenance & Mods (L322) > P0401-00 EGR Flow Insufficient - what to do? |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
I'm already one step ahead of you there. I've had the plenum off a few weekends ago to clean it properly, and did the EGR intake pipe and throttle body at the same time, sealing the throttle with high-density PTFE when refitting for a proper seal. By removing the plenum, I was able to access the EGR inlet pipe along with the electric motor, so removed those to access the valve and clean that too.
Sounds like a plan and good luck with it. My EGR cooler is weeping coolant but it's a pig of a job to change so I've opted to just top up the coolant every so often rather than paying >£2k to have it fixed. 2012 TDV8 Vogue (L322) |
Good news on the cleaning front (I hope). I’m not finished yet as awaiting some new gaskets for the EGR pipes before I put it back together and hoping they get delivered tomorrow. However, the wet vacuum worked a treat!
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 116 ![]() ![]() ![]() |
Just a wild idea reading this post:
SpitfireS, this is not a wild idea at all and was the genesis for my thinking/planning when doing this. I’m aware of companies like Terraclean that promise miracle cures but it’s just snake oil as at no point do they do anything that gets direct contact with the areas or concern; it’s always a secondary effect such as after combustion.
Update.
Would you, Ajmngn, say it's possible to clean the EGR the way you did but without the fluid vacuum cleaner?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4311 ![]() ![]() ![]() |
Great write up. Just my 2p - if I had the DPF diagnosed as needing replacement then I'd have gone straight to Empire Tuning in Colchester and had the DPF and EGR "sorted" |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1783 ![]() ![]() |
All good and well currently, but the MOT Test will be bring in PM testing at some point (already undergoing trials in selected stations)
Noted |
SpitfireS - the fluid I used works by dissolving carbon so deposits become suspended in the liquid. Therefore, if you put the fluid in then it needs to come out somehow, and I’d suggest measuring volumes before and after so you can gauge how much may remain before attempting to restart the engine. The risk of hydrolocking the engine is real, so it is imperative to remove the bulk of the liquid. I was initially just going to flood the EGR valve and cooler assembly and leave overnight. That would be the optimal solution. However, I elected to learn by doing and take it easy at first, so I chose to spray it through the EGR assembly instead. The logic was that an incremental approach would be better, as I could always use the flooding method as a next step if spraying didn’t work. I’m optimistic I won’t need to do that now but am confident I could if needed. The wet vacuum was the thing that made it a sensible endeavour as the suction achieved through the EGR assembly was excellent. You could try other options instead of a vacuum, but I can’t think of a more practical or easier way to be sure what went in came out. I would also ward against thinking you could get a hose down the outlet sufficiently to draw the fluid out using something else, like a suction pump. I struggled to get my endoscope past the EGR temp sensor on the outlet pipe and didn’t want to damage that by trying to find a way past. The sensor is only half way down the pipe to the valve gallery and you would need a hose to get right down into the gallery to get the fluid out sufficiently. 👍
Update 2
Not sure what chemicals actually ‘dissolve’ carbon. If it’s blocked with the kind of the stuff found in the intake it will take something more aggressive than a soak and flush. Also there is a possibility it’s not blocked and it’s a sensor error. 2012 TDV8 Vogue (L322) |
Hello Ajmngn, I'm sorry to hear the code came back.
