![]() | Home > Maintenance & Mods (L322) > Experience Modifying Suspension Height with IID? |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 163 ![]() ![]() ![]() |
lowering suspension will make it even more soft. |
If it’s’s ‘floaty’ you need new shock absorbers. Most think the later cars are too firm so careful what you wish for…. 2012 TDV8 Vogue (L322) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
It's not the shocks / any issue with the ride. I'm just asking for people's experience, knowing some members have adjusted the suspension height settings. 2015 Range Rover Autobiography 4.4 SDV8 |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 ![]() ![]() |
I lowered mine by about 10mm all round for a while, you get a feeling of being able to throw it around corners a bit quicker, certainly felt more stable, give it a go you can put it back easy enough to standard... |
I ran mine 12mm lower all round as I have 255/55 R20 tyres so this is actually setting it to stock ride height. Didn't notice any difference in handling and preferred the taller look so put it back up. 2012 TDV8 Vogue (L322) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35466 ![]() ![]() |
you can get a more solid ride by changing the tyre/wheels to a bigger diameter/lower profile. ... - .- -.
pos51 is strong drug. ![]() |
Syntetic drug invented by Elmo McElroy. Very popular in UK a time ago (joke). Unless suspension will not hit bumpers then lowering in l322 will not make it more stiff. It is impossible due to l322 air suspension construction. |
