Home > In Car Electronics (L322) > 2011 L322 Bluetooth module
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Phone suddenly won't connect and suspect the bluetooth module has gone on the blink. Easy enough to swap, but how do I know which is the correct unit for my car, there seem to be several that outwardly look the same but have different numbers (mine is AH42 10F845 AA if that's the right identification)? It also has an SN number that is different to another AH42 unit I found online. Any help appreciated.
Thanks. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #666527 13th Jun 2023 4:36pm
Weegie
Can't assist with models of Bluetooth modules but I would expect different Serial Numbers on different items as they are normally to identify the specific unit. John
GAP iiD BT-Sold
Post #666542 13th Jun 2023 8:36pm
rvbush
That's true (and pretty obvious to be honest, feel pretty silly now!!). Anyway, I've noticed that some available units have the number BH22 10F845 AA, rather than AH42 10F845 AA and appear outwardly exactly the same. but are they? Drives:
Post #666579 14th Jun 2023 3:34pm
there's info in the wiki.. Thumbs Up ... - .- -.
Post #666581 14th Jun 2023 4:18pm
Tiprat
I was just wondering if instead of using a RR part can we not use a Ford part from the same years? Having looked online at things like the Mondeo, Focus ect the look the same connections... Borrowed Grey 2002 3d 204k for a year
Now own a 2007 Java black Vogue SE 3.6TDV8 160k
Post #666595 14th Jun 2023 6:39pm
rvbush
Stan: the info on the Wiki (unless I'm missing something) seems to be limited to a list of part numbers. I can't find where the part number is listed on the module itself and I'm afraid I don't understand the Wiki post. The other Wiki post seems to be about updating the bluetooth module on earlier cars. I'll have another look. Thanks. Drives:
Post #666639 15th Jun 2023 8:40am
this seems to be a common problem..
put 'bluetooth module' into our search function and i'm there'll be a thread that will help you....
you'll have lots to read i'm afraid. ... - .- -.
Post #666642 15th Jun 2023 8:50am
rvbush
I've done that as well Stan, thanks, but I'm afraid there's nothing in there about the individual numbers on the unit. There seem to be a few available online, but they are all the BH22 type, not the AH42 which is what appears to be fitted to the L322. The question is, are they interchangeable (all connections look identical, but they may not be compatible)? Drives:
Post #666660 15th Jun 2023 11:59am
i'm sure someone has done this before so hopefully you'll get the answer soon.. ... - .- -.
Post #666661 15th Jun 2023 12:09pm
rvbush
Forget all the above, found an AH42 unit! Hopefully it will solve the problem. Thanks all. Drives:
Post #666662 15th Jun 2023 12:14pm
rvbush
Just to round this off, replacement AH42 unit fitted and all working perfectly. Happy days. Drives:
Post #667283 22nd Jun 2023 8:40am
BigEnglishWagon
New Zealand 2005 Range Rover Vogue 4.4 V8 Adriatic Blue
Mating connector for module
Did you get a mating 32 pin connector with the module?
If you had to get one, do you have the part number and supplier please.
Regards
Post #669964 28th Jul 2023 6:32am
