Home > Technical (L322) > Creaking noise from steering and suspension
JayGee
At low speed when the car has warmed up it’s quite pronounced and I can feel it through the steering. It’s like metal binding in a rubber bushing. <12 months ago had new upper and lower control arms, arb inc drop links and new steering track rod ends. Will have to get under it while someone turns the wheel and have a feel and listen but any pointers? 2012 TDV8 Vogue (L322)
Post #666494 13th Jun 2023 8:30am
Sandyt
Were the front arms torqued up under load if not it could be that ?
Post #666514 13th Jun 2023 2:00pm
The chrome plating on the rack ends can wear off, makes a hell of a squeak....
 Pete
Post #666516 13th Jun 2023 2:13pm
JayGee
@sandyt - I'd assume they were as Glenrands did the job.
@Haylands - more of a popping than a squeak 2012 TDV8 Vogue (L322)
Post #666520 13th Jun 2023 2:53pm
robanzac
New Zealand
When I had a creaking noise under the front it was the anti roll bar bushes.
The creaking was most noticeable over speed humps.
Tried a lot of things before getting to that and still find it hard to believe that's what it was as they seemed to be fine on inspection.
I could never make them creak up on the hoist and squirting them with silicone never even made a temporary difference.
So I ended up doing them on the basis that I have to try something next - and that is what it was.
Fitted these from Powerflex about 30,000km ago and have been fine.
https://www.powerflex.co.uk/product-detail...12898.html
But there are probably other types available.
The originals are bonded to the bar, so have to be cut off and cleaned up.
I removed the whole bar to do that. The new ones are not glued on[/url] Rob
Post #667662 26th Jun 2023 11:23pm
