Home > Maintenance & Mods (L405) > Drivers Electric Head Rest Not Working
HenryFrancis
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Hi all,
I've had my L405 Vogue SE a week or so now and everything appears to work as it should, with one exception.....
The drivers electric head rest doesn't operate at all. I can hear it trying (sounds like a relay or something operating) but the headrest doesn't move. Interestingly, the rest of the seat functionality works as it should.
Any thoughts or experience on what this could be? It's under a warranty - although if it's an easy enough fix I'd rather do it myself than mess around.....
Cheers
Post #666360 11th Jun 2023 12:31pm
Can you hear a motor whirring? Its on a worm motor so, you should hear the motor working at least... Thumbs Up
Post #666369 11th Jun 2023 2:52pm
HenryFrancis
Unnecessary quote removed
Hi Craig,
No, I can't hear a motor whirring when trying to raise or lower - just a slight clicking.
Post #666380 11th Jun 2023 6:44pm
Then it maybe the wiring plug has pulled out of the headrest motor... Not very hard to get at if your willing to strip the back of the seat a little... Thumbs Up
Post #666397 11th Jun 2023 11:32pm
HenryFrancis
I'm not scared!..... Big Cry
I'll give it a go, do you happen to know if there are any tutorials/videos/haynes type instructions anywhere?
I'll have a "google"....
Thanks again.
Post #666405 12th Jun 2023 8:16am
You might want to fill your car profile in sir… That was peeps will chirp in if they know which model it is you own and can help… Thumbs Up
Post #666411 12th Jun 2023 8:48am
HenryFrancis
DONE - Thanks Smile
Post #666420 12th Jun 2023 10:55am
As it’s a 13MY… Simply remove the lower seat back cover. A couple of lower elastic clips under the seat, I think you need to remove the two side covers to allow the lower back cover to pull outwards clear of the mechanism it clips over. Then the seat back lifts upwards and comes away in your hands! Then move the seat upwards and forwards, then get a torch and lay down behind the seat and look upwards inside the seat and you should see the wiring plug…
If you need to get more access I think you then remove two screws and the upper panel unpicks from the outer of the seat and pulls off…
It’s easier when your in front of the job to understand the above… Trust me 😳🥴🤪😏👍
Post #666426 12th Jun 2023 11:23am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
I had this exact problem with my drivers headrest, click but no movement and was indeed the multiplug had come adrift. I suspect when the seat airbag overlay loom had been installed they failed to clip the loom back into place.
 L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #666463 12th Jun 2023 7:25pm
HenryFrancis
You guys are legends.
I managed to undertake the fix last night following Craig's instructions - it was easier with the seat in front of me Smile
Easy fix - the wiring loom was loose and the head rest now works flawlessly.
I took the very same photo as 4RRS, but I won't bother uploading it now as you beat me to it Smile
One slight (and perhaps unrelated) issue is that on this mornings commute I could hear a spurious audible "beeping" noise that I haven't heard before - I'm hoping that this isn't due to reconnection of the headrest!
Post #666492 13th Jun 2023 6:56am
Really glad to be able to help you sir… 👍
Post #666499 13th Jun 2023 8:17am
BurnsideDalesbreds
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
Do they all have electric headrests on the drivers side? I have a 2014 Ab and I tried to move it manually but couldn’t, wondering if I’ve missed a button on the seat? 😂
Post #668071 1st Jul 2023 12:29pm
CS
On mine the headrest is moved by pushing the seat back adjuster (on outer edge of seat base) up or down. Yours might have a separate button above the seat back adjuster. Only Range Rovers since 1988
Post #668080 1st Jul 2023 1:14pm
Push the backrest button up/down to adjust the headrest sir… 👍
Post #668081 1st Jul 2023 1:17pm
BurnsideDalesbreds
Fantastic! That’s it, thanks folks! What a schoolboy error 😂😂
Thanks all 👍
Post #668083 1st Jul 2023 2:25pm
