Battery voltage above 12.6 at key on, engine off?
Do the LED's on the suspension control light up?
I've had the same problem when the battery voltage has gotten too low. As well, even if battery was charged enough if the key was switched too quickly after applying voltage I would see the same.
In my case, installing a new battery/connecting a charger and ensuring voltage was above 12.6 and letting the car sit and initialize for a few minutes prior to keying "on" allowed the communication to the suspension module through my diagnostic tool.
Also I was seeing a can bus error on the steering angle module when the air suspension module was offline.
