Home > Maintenance & Mods (L405) > Load area covers
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Load area covers
Hi
How do I remove the load area covers in the load area of my 2016 L405? I've pulled and pulled on the drivers side (uk) but it's not budging.
Is there a certain technique or is it simply brute force and ignorance needed?
If anyone has some pics of a video of how it's removed i'd be grateful
Regards
Mark L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
L322 2011 4.4TDV8 Vogue SE Alaska White/Charcoal - Gone
and lots of other none LR stuff…..
Post #665954 5th Jun 2023 1:30pm
Are the rear seats in the forward / upright position ? If reclined they can hold the shelf in place.
Post #665956 5th Jun 2023 2:23pm
nambFFRR
In trying to get access to the fuses in the side of the car. The main parcel shelf is easily removed. I just can't seem to get the side cover to unc!ip? L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #665961 5th Jun 2023 4:14pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
I had to move the seat right forward to let the side panel come free. First time FFRR owner
Post #665963 5th Jun 2023 5:02pm
i know what you're trying to do..
as you look at the panel, pull from the top left and then gradually prise from that side.. ... - .- -.
Post #665964 5th Jun 2023 5:34pm
Ah - sorry - I misunderstood.
This is what it looks like once opened - you can see the middle clip on the bottom left this photo - and it gives you the idea - pull from the top as though it's hinged at the bottom.
Post #665970 5th Jun 2023 6:34pm
nambFFRR
Ah….thanks….I’ll give it a tug again tomorrow and see how I get on👍 L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #665987 6th Jun 2023 12:05am
It takes a hell of a tug, more than you think.....!! Use the vents in the top of it that are in the recessed part, you can get your fingers through the vents to be able to pull it hard enough Thumbs Up Pete
Post #665995 6th Jun 2023 8:13am
nambFFRR
Thumbs Up L405 2016 4.4SDV8 Autobiography Corris Grey/Pimento - Current
Post #666026 6th Jun 2023 5:24pm
