Home > Technical (L405) > 2013 SDV8 L405 Air Con Drain tubes?
Neil183
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Hi
I have had a nasty smell from the air con for quite some time on start up which I'm told is probably from blocked drain tubes.
I've had a good look underneath (I expected to see a couple of rubber pipes hanging low somewhere) but cant see anything likely.
Does anybody know where these are exactly so I can go at them with a coat hanger please??
Many thanks
Neil
Post #665893 4th Jun 2023 4:02pm
Merchy
Important point first, I do not know where the drain tubes are on an L405....BUT.....do not start pushing a hard wire such as a bent coat hanger into these tubes, that's an instant recipe for damage Big Cry use something like the plastic from a garden strimmer coil, or something similar that is flexible.
Check the wiki section and post search function for info I am sure I have seen other posts on this subject Thumbs Up
Post #665894 4th Jun 2023 4:47pm
Neil183
OK, will do!
Cheers
Post #665897 4th Jun 2023 5:44pm
