Home > Site News & Feedback > This is not about FFRR but about the site search function
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
If I do a search and then read one of the topics when I use the back button it says the page is expired so I have to search again if I want to read another topic. Is this the same for everyone or am I missing something obvious.
Post #6658 4th Aug 2009 12:27pm
dan_uk_1984
Unfortunately I think it's a limitation of the site's basic coding....
If I'm searching for things, I open them up in a new tab (ctrl+Click) and then after I've clicked on as many as I think are relevant I then go through them all. If you still havent found what your looking for, you can keep browsing as long as you didnt close the original tab....
I use the same principle for google because often to get the info I need, I might want to quickly scan through multiple pages but still having the main search results for refrence.
Depends how much research you do daily really to find what works for you.
Dan
Post #6659 4th Aug 2009 3:07pm
Martin
Site Admin
Moved to the site feedback forum.
It is as Dan says a site "feature" - because the search is based upon the text you enter, the browser can warn that it believes the page has expired (because there might be new data to show you). You should be able to refresh and it will re-submit the search without having to start all over again.
What browser are you using?
Post #6660 4th Aug 2009 3:23pm
