Home > Maintenance & Mods (L322) > Replaced rear upper and lower control arms
colalowe
United Kingdom 2012 Range Rover Autobiography TDV8 Buckingham Blue
So I decided to replace the rear upper and lower control arms, the reason is because the car seems to feel all the small imperfections in the road and the bushes didn’t look great. I have previously replaced the knuckle bushes but haven’t done the shocks yet, mainly because others have with little results.
Anyway pig of a job due to very little space around the upper arm, one of the issues I had was removing the air spring.
I tried using the GAP tool to deflate the corners, this made the bag softer but it was still full of air and wouldn’t compress, I tried deflating the whole system but had the same result. I left it in place and when I dropped the lower arm the bag extended.
In the end I had to disconnect the bag to get it to deflate fully so I could compress it to get it back in.
I am now wondering if I have a faulty valve block on the rear that’s not fully releasing the air when needed.
Any thoughts 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #665373 29th May 2023 11:03am
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
Need to do the same, rear suspension squeeking when moving up and down.
Post #665454 30th May 2023 7:39am
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
I'll be doing the same, once all the parts are available. Nuts and bolts on back order since early May. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #665464 30th May 2023 9:57am
JayGee
Also look at replacing the track control arms which adjust the toe and getting a 4 wheel alignment done afterwards. 2012 TDV8 Vogue (L322)
Post #665517 31st May 2023 8:41am
colalowe
I ordered all mine from Advanced Factors and they were here two days later 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #665531 31st May 2023 10:27am
That would be for pattern parts, I imagine Tommy is wanting to use genuine parts... Thumbs Up Pete
Post #665542 31st May 2023 11:08am
TDV8_Tommy
Yes, I am waiting on genuine parts. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #665548 31st May 2023 11:32am
