Home > Maintenance & Mods (L322) > Binding Parking Brake :x
Marti92
United Kingdom 2012 Range Rover HSE Td6 Barolo Black
Hi Guys!
Got the “brake pads worn” message the other day, good timing as I was planning on using this bank holiday to do the rear pads and disc.
I did the steps to put the car in “ service mode “ before doing anything, passenger side went fine no problems.
Drivers side is another story, the disc was firmly stuck, nightmare.
Once it was finally off, I’ve cleaned everything with brake cleaner and attempted to refit the new disc only to find it wouldn’t fit over the shoes, I can squeeze the disc on but then I’ve got no adjustment left on the cog for the shoes to loosen to let the wheel spin freely.
I adjustment it off as much as it will go and tried the car up the road, the parking brake is definitely binding and I’m at a loss Bow down Big Cry Big Cry
I’m still yet to do the bedding in process (been waiting for the traffic to calm down)
Am I wasting my time trying to bed them in?
If anybody can help I would be very thankful!
Thank you!
Post #665419 29th May 2023 5:48pm
Firstly welcome to the asylum sir...
Im a little confused as to which model RR you have? Your car info states you have a 2012 TD6 Embarassed Whistle
Post #665441 30th May 2023 12:12am
Marti92
Thumbs Up Thumbs Up
It’s a 61 plate RR sport 👍🏻
3.0
8 speed
Post #665444 30th May 2023 5:28am
DrRob
The "Sport" has its own forum which might be better placed to answer for that model Thumbs Up
https://www.rrsport.co.uk/forum/index.php?...34740c5b92
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #665452 30th May 2023 7:16am
Marti92 wrote:
Thumbs Up Thumbs Up
3.0
8 speed
Aha yes, you have joined the wrong forum sir… 🙏👍
Post #665458 30th May 2023 8:44am
