Home > Maintenance & Mods (L405) > Rear lights
Seatown
Scotland 2013 Range Rover Vogue SE SDV8 Firenze Red
Rear lights
The first proper sunny day since I got my L405 (I am in Scotland Laughing ) and I discover this has happened to both rear light lens covers. It's not impact damage, they were perfectly fine when I parked the night before Big Cry
Has anyone successfully replaced the lens covers or is it new complete unit time?
Post #665371 29th May 2023 10:51am
I'd have a look on the powerfuluk site and see if they do a lense replacement ... - .- -.
Post #665379 29th May 2023 12:02pm
Seatown
Thanks Stan.
Yes I've seen their ones and was wondering if anyone had used them. It's a pity the guys at Powerful haven't actually trialled it themselves. There seems to be some debate as to whether the covers are adhesive bonded or heat welded onto the the lamp bodies.
It's a real PITA, JLR using materials like this that age so poorly although I have had a similar sunshine induced cracking incident with the polycarb speedo cover on a Ducati.
Post #665381 29th May 2023 12:11pm
Powerful do sell them, they also state they have never changed one and there is a reason for that...
It is virtually impossible to get the old lens off without damaging the light unit somewhere....
It is also virtually impossible to get a good seal of the new one and not get fogging problems...
Unless you like lots of faff and a finished job that is not as good as original I'd just pay for new ones...
Maybe update to the 2018 ones... lots of pattern ones about that are at least as good as original by the look of yours...!!!
Thumbs Up Pete
Post #665382 29th May 2023 12:14pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
As Pete says, it’s impossible to remove the lens from the main unit without damaging it - I’ve tried.
The lens is plastic welded on - even if you do manage to remove it, attaching a new lens is nigh on impossible too, as the replacement lenses don’t quite fit the curvature and short of having equipment to plastic weld it back on, no glue will hold it - again, I’ve tried.
Not sure why they sell the replacement lenses as in my view, they’re unusable Rolling Eyes Jonathan
2007 Defender 90 XS Hardtop
Post #665391 29th May 2023 1:15pm
Seatown
Thanks for the replies chaps. Confirms what I suspected.
I'm minded to replace them with 2018 style units. There are a few fleabay sellers (e.g. MZOrange) that supply them complete with an adapter cable for the earlier wiring and at a hefty saving over the Powerful ones.
Has anyone any experience of these aftermarket units?
Post #665393 29th May 2023 1:24pm
caymanblack
What caused this in the first place? overfinch modified
Post #665398 29th May 2023 3:00pm
Pretty sure it's sun damage, cheap plastic... Pete
Post #665401 29th May 2023 3:47pm
Seatown
Caymanblack - as per my first post it was caused by the sunny day yesterday. I think the polycarb covers have aged (car now 10 years old) and I suspect the direct heat of the sun caused the stress cracking. I've only had the car just over two months so I'm not impressed to say the least - plus I had brake failure on Friday - I'll post separately about that!
p.s as far as I'm aware they are the original rear lights.
Post #665410 29th May 2023 4:58pm
knwatkins
Wow Kev, you really are having some bad luck with your L405 over the past few days.
I've heard varying reports of the aftermarket rear lights - some say they are not as bright as the OEM ones. No experience with them myself, but something to consider. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #665427 29th May 2023 7:12pm
I have several sets of used rear lights and several sets of new lights in stock if you want some sir... Drop me a PM Thumbs Up
Post #665438 29th May 2023 11:49pm
Seatown
Thanks Craig, have done so Thumbs Up
Post #665500 30th May 2023 9:39pm
