![]() | Home > Camping, Caravanning and Holidays > Tyre Pressures when towing a Caravan |
RoastPenguin Member Since: 11 May 2023 Location: West Midlands Posts: 29 ![]() ![]() |
Try in between and then full load. I didn't change pressures when towing with my D3, it was fine. My audi though..had to whack all 4 up to max load pressures to get it feeling OK. Yet to try the l322 but I'll be trying mid point then full load |
Hanwellfields Member Since: 22 Dec 2022 Location: Oxfordshire/ Cotswold Posts: 89 ![]() ![]() ![]() |
L322 not L405 but… Cabin loaded with car bits, fully fuelled. Trailer with small track car but also tools and spare wheels. PSI was set at mid point when cold. However when warm had increased to closer to full load values. Was perfect on 220-mile round trip. No wandering or “bouncing” at all.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1396 ![]() ![]() ![]() |
No caravan experience, but with the trailer my rear tyres are inflated to 42psi, which I think is what LR recommend and has been fine. Fronts stay at normal 34psi. Only Range Rovers since 1988 |
Just to add to this, towed mine a couple of times now, pretty much fully loaded on last trip.
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 295 ![]() ![]() ![]() |
I guess I looked at this differently - I never changed my rear tyre pressures when towing a big 2000kg+ caravan... the additional downward weight on the tow ball was only an extra 98kg so as long as the car wasn't unusually/fully loaded I didn't think it would make much difference? You'd hardly know the caravan was there so I just stuck with that. In my mind it was more effort required in moving it forward, not taking on loads of extra weight to the rear.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8444 ![]() ![]() ![]() |
Tyre pressures are determined by temperature...
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
James,
Completely agree on heavy caravans, when I sold mine and emptied it I was quite shocked at what had slowly accumulated over the years and was probably taking the caravan over its plated weight. But (unless the caravan is loaded incorrectly) that extra weight still doesn't sit on the tow ball as a downward, additional weight on the rear of the vehicle does it? It is 'rolling mass' pulled by the vehicle, but the nose weight is controllable.
I only mentioned my experience when the ATC was turned off to inform other people of the dangers of not having the correct setup to start with, tyres, car to caravan/trailer weight, etc. as it soon becomes a big problem. 2017 SDV8 4.4 silicon silver AB
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
Not any more - as VOSA/DVSA/Wombles move towards privatisation they will become more "all-encompassing". I was told this by a DVSA Officer. However, he did say that "if you look tidy" you are unlikely to get a pull. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8721 ![]() ![]() ![]() |
It’s surprising what small changes can make a big difference.
