Home > Technical (L322) > Height Sensors Am I doing it Wrong? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7647 |
I had exactly the same issue when I did my front left. Ended up cutting the old sensor off the bracket. Luckily I found bolts to go to the bracket, so fastened new sensor to old bracket with those. The bracket is over £100 from LR… I know as I rang them…. Though I think some aftermarket sensors might come with the brackets which would make the whole job easier… but with this fix, it’s best to stay with LR height sensors if you can.
25th May 2023 6:35pm |
Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 73 |
Had exactly the same problem, Dremel to the rescue I'm afraid! |
25th May 2023 7:24pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 256 |
Same here; 30 mins under the car with a junior hacksaw to cut the sensor off the bracket. TDV8 4.4 2012 |
25th May 2023 9:00pm |
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 114 |
Still haven't done this yet-think I'll just smash the sensor off with a chisel and then attack the bolts. Any reason why I shouldn't do it this way?? Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
28th Jun 2023 7:28pm |
You can just unbolt the bracket with the sensor attached, and then attack it off the car. You need the bracket so don’t damage it. No reason to be faffing about laid on your back etc….
28th Jun 2023 8:58pm |
Thanks, I will put that on the agenda for tomorrow afternoon - be a nice contrast to school speech day in the morning... Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
7th Jul 2023 9:36am |
By the way I ended up using a powerfile sander on the bolt heads and 10 mins later it was off. Removing the bracket on the rear is a bigger job, using the powerfile made it a doodle once i got the angle right. Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
24th Apr 2024 8:16am |
