![]() | Home > Technical (L322) > 4.4 TDV8 engine rattle & auxiliary belt issue |
ctjfb Member Since: 20 Jun 2019 Location: Northampton Posts: 32 ![]() ![]() |
I have an ongoing issue with my 2012 L322 TDV8 4.4 ..
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
I think someone on here had something similar and they found the power steering pump was loose. |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
did you manage to resolve issue? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
No - I haven't resolved this yet .. I have it in bits again and am re-checking the PS and AC pumps for any bearing issues ... Chris
Looking forward to your finding |
Did you end up solving your rattle issue? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 289 ![]() ![]() ![]() |
Try changing the power steering fluid; I had a low rubbing noise from that area that I couldn’t track down. Then did a full fluid service, including PS fluid, and it went away never to return. PS fluid is cheap to do so there’s nothing to loose. TDV8 4.4 2012 |
Mine has a rattle aswell, and it goes away once the viscos fan kicks in or if I put load on by twisting steering side to side.
It is the aux belt SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
bradleypaulclarke Member Since: 10 Jan 2024 Location: Essex Posts: 2 ![]() ![]() ![]() |
Did your issue get solved? I have the exact same noise on my 4.4 and i have only found a couple videos like this that sound the exact same as what im experiencing |
s1tommy Member Since: 20 Mar 2024 Location: Coventry Posts: 4 ![]() ![]() |
After doing an alternator and belt change, I know have this exact rattle and cannot get to the bottom of it. Can anyone chime in and give some info/fix please? I did see that the OP changed the belt again and that cured it, as to which I have also done but the rattle still persists. Any help is much appreciated. |
You may have checked this during your belt change; Sam goes through belt alignment below and checks it with a straight edge but doesn’t really say how….. it may be worth checking your alignment and looking for belt debris on the ancillaries.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
is noise still there with the fan not fitted? |
