![]() | Home > Maintenance & Mods (L405) > L405 SD 4.4 Oil Change (2017) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
With oil capacity you have a minimum and maximum the engine will like, the minimum amount it will run on with no bother is less than the lowest level on the "dip stick" be it a real one or electronic level indicator...
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
I can only relate to the 4.4 in the L322, but anything over 8.5 litres of new oil immediately brings up the “overfilled” refer to handbook message.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
I'd recommend getting the level indicator fixed in the first instance. There really is no reason not to do this. Then you know exactly if you have the correct volume in there to start with.
That's not the case on my L405 SDV8, Mike. I can suck out exactly 9.4 litres and replace it with 9.4 litres fresh and the indicator will show full. Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Suki Member Since: 21 Oct 2022 Location: London Posts: 15 ![]() ![]() ![]() |
Thanks for the replies all. It seems it's not so simple after all.
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1153 ![]() ![]() ![]() |
Suki have you enquired about getting the sensor repaired? overfinch modified |
I understand it's a big job, since the sump needs a stripdown. I've heard reports of £900 or more.
IIRC it's a huge job on the 405 as the sensor is in the sump, on the 322 it's outside the sump...
PLC Member Since: 23 May 2022 Location: Stafford Posts: 18 ![]() ![]() ![]() |
I changed my oil 2 weeks ago i know its supposed to be 9.4 litres to change but i dont like to overfill, i put in exactly 9 litres of smith and allan oil and the gauge reads full - oil level ok hope this helps |
Great thank you! I think this is what I'll need to do. |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1264 ![]() ![]() |
Do a search there are other reasons why the oil gauge is not working
