![]() | Home > Technical (L322) > Sump temperature is climbing very hot!!! |
SPOautos Member Since: 13 May 2023 Location: Alabama Posts: 4 ![]() ![]() ![]() |
Does anyone know exactly where the sump temp sensor is located? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1456 ![]() ![]() |
@fisha I appreciate the info.....Have you happened to ever look at your sump temp at idle with a scan tool? What is normal for these specific 5.0 Supercharged engines? Someone told me even with intense mountain driving they have never seen their sump temp reading get over 220f but maybe they were looking at something else like regular oil temp...not sure.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8518 ![]() ![]() ![]() |
Not many 5.0 S/C's over this side of the pond, mostly diesels, USA forums and the Jag forums will have more info on S/C's....
What is the ‘sump temp’ measuring exactly? The oil temp would be the crucial data I would think. 2012 TDV8 Vogue (L322) |
chdavis Member Since: 29 Nov 2021 Location: Washington DC Posts: 45 ![]() ![]() |
My oil temperature is usually a bit cooler than my coolant temp. What weight oil are you running? 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
