Home > Maintenance & Mods (L322) > Please identify this knob...
Reggie
United Kingdom 2007 Range Rover Vogue SE TDV8 Santorini Black
This rotating knob sits on the lower front of the driver's seat. There isn't one on the other side.
I can't fathom what it does and can't find any reference to it in The Book.
Can someone here help please?
(RR is a 2007 3.6tdV8 Vogue SE)
Best wishes to all and many thanks
Reggie
https://www.fullfatrr.com/gallery/albums/u..._4258.jpeg
Post #663768 10th May 2023 4:29pm
i dont recognise that ..might be after market..
Post #663775 10th May 2023 4:51pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Ejector seat button? Whistle 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #663776 10th May 2023 4:53pm
Reggie
If it's for the ejector seat, it's not working Very Happy
(Passenger seat still firmly attached)
As for after-market, I initially assumed it was a fader knob. But it doesn't do anything to the sounds...
Maybe I should try to trace its wiring back to something? ( I am very un-techy, so that will be a challenge!)
R Smile
PS: Thank you, Stan, for putting the photo in the thread - I couldn't see how to do that Embarassed
Post #663777 10th May 2023 5:03pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
My 08MY 3.6 TDV8 Vogue definitely did not have that on the drivers (or passengers) seat. Confused The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #663778 10th May 2023 5:08pm
i think thats the only way to find out what it is Reggie..,you might even be able to see from the back of the seat . ... - .- -.
Post #663782 10th May 2023 5:44pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Reggie, could it be from a previous owner making adaptions for a disability perhaps? A mounting bracket or fixing point. Just a thought. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #663783 10th May 2023 5:46pm
johnboyairey
My seat side cover broke about there, and I used a countersunk black screw to hold it back on. Could this be a crude repair to hold the seat valance cover back on? There’s a loop behind to locate it I think.
Post #663893 11th May 2023 6:27pm
Reggie
Thank you all for these thoughts.
The only previous owner is a friend and unfortunately he has no clue as to what it is.
We still haven't worked out how to use the FBH or what the venture cam is for!
I have had a closer look (seat in fully-up position etc for access)
The knob rotates easily, there is a block on the back of it. The moulding appears to be prepared for it, the block is screwed into the moulding properly. The lead from this block runs to another block which has a modem-type connector plugged into it.
That wire disappears into the large block of spaghetti/plastic/stuff under the seat.
There are no manufacturer markings but the block attached to the knob has a date sticker of the type used by LR. (December 06, which ties into the build date)
The only thought I have is that it is an aux volume control for the (currently disconnected) rear passenger entertainment?
(or the actual passengers, if that's possible? Very Happy )
Do you think I'm heading in the right direction please?
(I want to take it out as it's ugly, but not if it's correct)
All help gratefully received as ever.
R
Post #663950 12th May 2023 1:21pm
MarianaWestminster
Could it be an adaptation for disability?
Have you tried it out with the car running to see if you can identify any changes whilst turning it?
Post #663955 12th May 2023 2:53pm
Reggie
Hello again!
Yes, I tried with engine/radio/phone on but none seemed to change in any way.
As for adaptation for disability, I don't believe so. My friend bought the car new and I have known it since then - including when and where serviced etc. The head unit was upgraded a couple of years ago by installers I know well - they swear this knob is nothing to do with them!
The car has a Tracker though (from new). I've had Trackers before and not had anything like this but could it be connected to that in some way??
It reminds me a little of those ADSL filters used for wifi routers - a small version.
It's mysterious for sure..... Question
Post #663975 12th May 2023 6:25pm
JayGee
Follow the wires - can you see them from under the rear in the passenger footwell? 2012 TDV8 Vogue (L322)
Post #664007 13th May 2023 12:18pm
Reggie
I've had another look under the seat - a bit more brave this time Shocked
The knob is definitely not genuine LR but aftermarket (all nicely installed though)
The LR date sticker I spotted before is actually on the seat trim itself.
I removed the knob from the seat trim. There is a sticker that says RLC on it.
The wire goes down under the main installation of kit that's under the seat - I can't see or feel any further...
It's an intensity control of some sort - volume/fade/dimming/etc - but I've tried all the toys I can find in the car and none seem to be affected by the mystery knob Cool
Planning to remove it but leave it connected, tucked under the seat. I can then fill the hole and stop fretting!
All suggestions of what RLC stands for are welcome Very Happy
Reggie
Post #664021 13th May 2023 3:29pm
Reggie
FOUND IT!
The car has a mega-upgraded hifi and this knob is a bass level control.
Lost on me as the radio is only on Smooth Radio if at all and only ever at low volume. I couldn't hear the difference!
No idea why they put it in that place though (then forgot they did it!)
I will ask them next week.
Thank you all
R
Post #664022 13th May 2023 3:36pm
''sounds'' like a result.. Thumbs Up ... - .- -.
Post #664023 13th May 2023 5:12pm
