Home > In Car Electronics (L322) > Sat Nav inop.
Byg Nyge
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
Sat Nav inop.
Sat nav does not work comes up with The disc is not a map disc. I've got an updated disc and get the same message. Using the onboard sat nav diagnostics it said there was no gps signal, I've changed the gps antannae and now have a list of satellites that I'm receiving a signal from but still get the disc fault message. Would it be worth trying to change the actual satnav dvd player?
Many thanks.
My car is a 2007 Vogue SE TDV8 3.6
Post #663719 9th May 2023 5:09pm
Fill in the car details on your profile, then we will know which model you are having bother with... Thumbs Up Pete
Post #663723 9th May 2023 6:02pm
Byg Nyge
Ha yes that would be a good idea.
2007 L322 Vogue SE TDV8 3.6
Post #663744 10th May 2023 10:22am
Weegie
Try going into the menu to see that it is set for UK. It can cause it to throw a wobblie. The default, for some reason, is Belgium. John
GAP iiD BT
Post #663752 10th May 2023 12:31pm
Byg Nyge
Got into the sat nav diag. and it is set to UK, lots of satellite co-ords showing, before changing the antannae I had none at all! Just doesn't seem to recognize the old disc or the update disc.
Post #663861 11th May 2023 2:32pm
Byg Nyge
All sorted, replaced the dvd player, £70 from Gentlemen Of Salvage. Updated map dvd also works. Happy Bunny! Thumbs Up
Post #664679 22nd May 2023 11:23am
