Home > My Range Rover > FFRR Ownership year one: 3 things I’ve learned |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 275 |
( Warning: lengthy post follows below )
9th May 2023 10:35pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Great write up and I agree on all points
10th May 2023 6:56am |
TPhipps Member Since: 24 Feb 2023 Location: Cotswolds Posts: 18 |
A great write up and thank you for your thoughts. I'm trying to adopt a similar approach with my 2016 L405 (2 months in ownership now!) and have had mega flush and diff oils changed as a preventative measure and 4-wheel alignment. Like the comments made by Bmax01 I hadn't considered using all the features and options to keep them lubed, flexible and in good working order. A good tip as I guess its easy to forget some of the less used options outside your normal day 2 day driving........so I'm now off to press all my knobs and buttons now!! |
10th May 2023 2:53pm |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 397 |
Enjoyed reading this and I agree entirely, thank you for taking the time to share
10th May 2023 6:00pm |
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 |
Great post. If you're an AA member, also worth taking their breakdown repair insurance cover, T&Cs apply, but I've used it a few times and other than for brake pipes, they've paid out which helps for those more expensive items, air struts, alternators etc. Worth a look for those older cars out of warranty FWIW.
10th May 2023 6:22pm |
Proftinkerpot Member Since: 22 Dec 2022 Location: County Antrim Posts: 179 |
This is an excellent article with a lot of helpful advice. As a FFRR owner since January, this makes perfect sense. I bought a 53k mile 2 owner car. Previous owner maintained the car himself and while I have receipts for parts, I don't have exact mileage when they were fitted but he covered 18k in 6 years and so even one mid term oil change would probably have been fine but i suspect it was done every other year or 6k miles. I also have receipts for a battery and starter motor and my garage confirmed serpentine belts, tensioners and waterpump have been changed. It was very clearly a very cared for car but I decided to get diff oils and transfer box fluid done and underseal applied. Car is just approaching 57k and I plan to get the gearbox flush done by 60k more because it probably has the original 2012 oil in it. Will change the engine oil and filter too.
10th May 2023 8:09pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3206 |
On the other hand......
10th May 2023 8:29pm |
I haven’t ever owned a 4x4 with a selectable low ratio before and was a bit nervous of it to start off with. Listening to some of chats at one of the Hampshire meet-ups it seemed that most folks drop into low ratio regularly to cause the selection mechanism to work and generally give the transfer box a different mode of operation. Having read on here about some horror stories of the mechanism sticking through lack of use, I decided I’d better stump up and try it. I should explain that the only previous owner to me was in his late 70’s and did 6k miles per year….so not much chance of low ratio being used much especially given the Covid sojourn during the prior years. So the first time though there was a bit of whirring and a clunk but the change was fine and it didn’t stick. So I kept trying it once a month and the change got progressively smoother. Then we had a holiday let down a long steep Welsh farm track which was an ideal excuse to both change into and drive in low ratio. Good fun and it all worked and I learned a bit about how much easier the vehicle is to control/manoeuvre. Again by the end of the holiday the whole change and drive seemed a bit smoother. I also read the handbook about changing into/out of low ratio on the move which suggests the vehicle can be traveling at 60Kph ( 38 mph ) when changing up from low to normal range. So this is a bit advanced but it does show its acceptable to drive at that speed for short distances in low ratio. After the transfer box oil change I wanted to give the oil a good circulation and as I live in an urban area simply decided to give it a spin around the block in low ratio. As I said in the post above each time I took a test type action the whole transmission just seemed to get smoother. So, trial and error really, but to my mind it has made a difference and it’s given me more confidence that everything is functioning. I can’t imagine anything more frustrating that being stuck behind something on a snowy cold winter’s evening; selecting “snow” mode on the terrain response to get around it only to hear a horrible sounding cluck and see a transmission fault warning on the dash! TDV8 4.4 2012 Last edited by Ramblin Man on 10th May 2023 8:47pm. Edited 1 time in total |
10th May 2023 8:33pm |
Now; that’s the thinking of a “proper” engineer ! TDV8 4.4 2012 |
10th May 2023 8:35pm |
Yes, fair point! There’s a justifiable practical mindset of don’t go looking for problems. Although for me, having aspired to a Fatty for many years, I like to steadily work toward keeping it tip top. It’s a long term “keeper” for me and I enjoy knowing it’s in the best condition it can be for its age. I guess if I were commuting the miles I used to I be a lot more practically minded about it. TDV8 4.4 2012 |
10th May 2023 8:44pm |
I have a lot of sympathy with this, but keep them in reserve for the bigger jobs mostly, that has worked out okay thus far & with the AA breakdown repair insurance as a back up for when the, hits the fan. Only one actual breakdown and recovery, brake pipe failure while parked, in very nearly three years. Fair play car. |
10th May 2023 8:53pm |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 251 |
Same here - I had more issues with my 3 year old Mk7 Gti than I've had with my 12 year old L322, including 4 new windscreens in 2 years. Okay, I admit it was cheaper to run! OP, very informative post thanks. 2011MY 4.4TDV8 Autobiography Baltic Blue TVR Griffith Alfa Romeo Mito QV |
12th May 2023 12:11pm |
camcc Member Since: 01 Oct 2023 Location: Godalming, Surrey Posts: 31 |
This is an extremely useful write-up for a buyer looking to purchase their first L322. Many thanks! |
4th Oct 2023 11:40am |
Thank you, pleased to know it’s been useful. I am already keeping notes for my year 2 write up. TDV8 4.4 2012 |
4th Oct 2023 1:31pm |
