![]() | Home > Maintenance & Mods (L322) > Egr blanking kit for 4.4 tdv8 |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3194 ![]() ![]() |
think you'll find that the 4.4 is best left well alone. EGR blanking will interfere with the engine settings/CPU and b*gger up your DPF regens (so I understand).
Craig5 Member Since: 05 May 2023 Location: Liverpool Posts: 42 ![]() ![]() |
so are they easy to remove and clean? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 ![]() ![]() ![]() |
Yes, the posts about issues and best removed or blanked generally relate to the 3.6. As above, best left alone on the 4.4 as affects things more.
so best to clean? |
Yeah, they can still get gunged up. Not sure if there is a how to in the Wiki.
hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 71 ![]() ![]() ![]() |
Not long ago I had a Quantum tuning remap including mapping out the EGR.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2554 ![]() ![]() ![]() |
I'll make my own plate when I get around to it, having had a very mild remap with EGR delete some time ago.
Yes to add, in the spirit of transparency (if those read my other recent posts) I've had DPF full issues recently but they have been unrelated to EGR blanking and since resolved. So don't let that put you off.
Most people have no issues with the EGR valve on these engines and see no reason to disable it. 2012 TDV8 Vogue (L322) |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
4,4 EGR is quite eternal part, almost never fault. There is nothing to clean, it just black inside like exhaust pipe, and you dont clean exhaust pipe, right?
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 216 ![]() ![]() ![]() |
If it ain’t broke, don’t fix it. |
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 139 ![]() ![]() ![]() |
In the interest of providing a balanced set of replies here, you can indeed remove/blank the EGR system. You just won't find a kit to do it so need to make your own. 2mm steel plate is fine.
As it needs a remap to get it to run without EGR flow why go to the trouble to physically blank it as well? 2012 TDV8 Vogue (L322) |
Pretty sure this has been covered before, but if mapped out it is to cover the possibility of a sticky valve surreptitiously leaking. Cam
