Home > Technical (L405) > Suspension Groaning when going down to access mode |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 455 |
Any knocking from the suspension on uneven road surfaces?
5th May 2023 1:21pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
As above anti roll bar bushes and drop links ball joints are possible causees, also on a 322 you can get a tiny bit of groaning when all is well if you drop to access height when the steering is turned over to full lock. Would imagine a 405 can do the same. |
5th May 2023 3:13pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Try it without the park brake on and no foot brake. Also do it on the level and in neutral. Does it do it then? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
5th May 2023 8:50pm |
Jay Porsche Member Since: 22 Jan 2023 Location: Solihull Posts: 59 |
No knocking at all its perfect whilst driving.
9th May 2023 9:15am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
I expect that is the pads getting pulled down the disc as the car lowers, as it lowers the wheels need to move a fraction in relation to each other, in park the brakes aren't on...
9th May 2023 9:36am |
