![]() | Home > Off Topic - Other Cars > common issues with e90 330i |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 195 ![]() ![]() ![]() |
Check the indicators, they don't get used much... |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1231 ![]() ![]() ![]() |
May be worth a good furtle on the interweb, try these below for starters - two friends have had these, they were quite reliable. Hope this helps. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
BMW did a recall a short time ago when this happened to a BMW driver who used the R.H. Indicator for the first time. ![]() 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35618 ![]() ![]() |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
Try asking on M3Cutters forum, someone will be able to help. IIRC these engines have the cam drive at the rear and can suffer failures. It's a bit like the turbos on 3.6 TdV8's, it's not a given but it can happen. Drives:
