Home > Wheels & Tyres > 19’s on a P400e LWB?
AnnualMan
Switzerland
Opportunity to buy some new genuine 19’s for winter use has come up (LR037742). The car is currently on 22’s which isn’t ideal for winter use, but at least winter tyres are available should I decide to just swap out the tyres each season.
Will 19’s just look silly?! 2018 P400e AB LWB
Post #663426 4th May 2023 3:26pm
yes they will ..
are you sure hey will fit over the brakes? ... - .- -.
Post #663438 4th May 2023 4:40pm
AnnualMan
Switzerland
Good point about the brakes!
So no go then 2018 P400e AB LWB
Post #663510 5th May 2023 10:45am
Gremlin500
No, it’s a no-go, 19” were only available on the V6’s which have smaller brakes (except mine Laughing )
Most V8’s seem to be with 21” or optionally 22” wheels to fit the bigger brakes, not sure about 20” fitting either TBH, perhaps someone else will advise.
The 2017 brochure offered 20” as possible except for the 5.0S petrol, but doesn’t mention the 4.4 V8 at all?
There are loads of used 21” about which you can get Winter tyres with a slightly taller sidewall, if that’s what you want. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #663513 5th May 2023 11:21am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
20” are OE and fine over the larger brakes.
Post #663514 5th May 2023 11:31am
Im guessing you will have to meet your territories needs too... Thumbs Up
Post #663548 5th May 2023 10:22pm
