![]() | Home > Maintenance & Mods (L405) > Coolant leak - help needed with part number |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 126 ![]() ![]() ![]() |
Looks like it has the Jaguar part number written on the hose. |
johnf Member Since: 16 Nov 2012 Location: Nottinghamshire Posts: 84 ![]() ![]() |
Thanks for the reply but I think that is just the hose spec rather than the specific piece. In any event I've now realised that isn't the source. I took the car for a drive and had another look with the engine warm. There was a weep coming from a bleed screw in the hose above. No problem I thought, I'll just nip it up. Unfortunately(and with hindsight rather predictably) the screw was very brittle and so broke off completely and water came gushing out.
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 229 ![]() ![]() ![]() |
I can't find any part reference for the bleed screw on its own, the part number for the pipe is LR034624 (Hose And Bracket) - about £80 retail.
Thanks very much Fifth Horseman. Looks like it is £80 for a bleed screw then - I think I'll just leave the pipe and bracket intact. Good idea about finding a screw - just need to look for the correct size/thread, luckily enough of the old screw remains intact to try and match.
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 202 ![]() ![]() ![]() |
Worth a punt, albeit delivery from China, loads on the site
Definitely worth a shot - how they should have been made from the start. |
Thanks both. Have ordered one and will let you know how I get on.
Success! One £4 bolt (as per the link above) and I'm up and running.
Well the brass bolt from China arrived - and wouldn't fit!
