Home > Technical (L322) > Increase fuel consumption AJV8 (petrol)
Grayson Welly
My car used to deliver about 400 miles to a tank for a mixture of urban and extra urban usage. A faulty thermostat seemed to be affecting it and was replaced... however, it now continues to deliver about 300 miles to a tank or about 18 mpg as opposed to 24 mpg.
I did previously have running issues which were resolved with a clean of the MAF, however, the car does run a little rough on idle (occasionally) and I'm wondering whether the MAF might be underlying this increased consumption. I have run a check on icarsoft and nothing obvious pops up. Any thoughts? --------
2006 Buckingham Blue/Parchment White AJV8 Vogue
Post #663366 3rd May 2023 1:50pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
That's Not bad, I'm currently only getting about 11 mpg Shocked
Post #663368 3rd May 2023 2:22pm
Grayson Welly
Oi! Go and start your own thread then! Laughing --------
Post #663370 3rd May 2023 3:15pm
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
I had something similar
I cleaned the MAf - still not great, changed MAF and reset the adaptations. (check external temperature sensor too) 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #663371 3rd May 2023 3:22pm
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
My MPG dropped on my 4.4 M62 with no errors, but got better again after I serviced it and changed the fuel filter.
I'd also check for any sticking brakes, feel the hub caps after a bit of a drive to see if one of them is warmer than the others.
Post #663402 4th May 2023 7:22am
