Home > Technical (L405) > Restricted Performance Issue
AmiDee
United Kingdom 2013 Range Rover Vogue SDV8 Causeway Grey
Hi. Bought a 10 year old Vogue L405 just 6 months ago. Have since had to, on the advice of LR after they serviced it, replace the oil cooler and coolant housing. Within 10 miles of getting it back from the LR specialist garage, my RR went in to restricted performance mode, followed quickly by the EML coming on. Had it towed back to the same garage and turns out, I now need 2 new turbos at a cost of around £6000!!!! Is this even normal? Why would both turbos need replacing? Could it be something to do with the garage fixing the oil cooler and coolant housing issue?
Any info, help, or advice will be greatly appreciated.
Post #663322 2nd May 2023 8:54pm
Jase71
United Kingdom 2017 Range Rover Vogue TDV6 Santorini Black
when my TDV6 threw the restricted performance light it was just the MAP sensor...£800 later and all was good! 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #663358 3rd May 2023 11:00am
supershuttle
Mine was also the maf sensor, just needed cleaning. Geoff
Post #663375 3rd May 2023 4:59pm
DrRob
Who’s the specialist you used out of curiosity? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #663379 3rd May 2023 6:59pm
AmiDee
Took it to Harris Mayes in Rickmansworth. Having waited nearly 2 months for parts being on back order, they were the first and still only garage that called me back to say they now had the part in stock. Reviews on google were all ready good too.
Post #663470 4th May 2023 8:35pm
johnboyairey
Re: Restricted Performance Issue
your response???
https://memes.getyarn.io/yarn-clip/fb77df4...e82de2275a
Post #663474 4th May 2023 9:14pm
