![]() | Home > Maintenance & Mods (L322) > HandBrake Cable out of the expander |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 ![]() ![]() ![]() |
If it's the same handbrake arrangement as my 06 TD6, then a pair of thin pliers will let you pull it out sufficiently to refit the actuator. You're pulling it against the spring-loaded adjuster at the handbrake end. |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
It's a cable with spring and then a bit is attached to the cable which latches into the expander.
Update: pulling the emergency release cable in the boot compartment sorted it. Could attach the expander to the cable.
