Home > In Car Electronics (L322) > Permanent live & switched live
Superspoons
Hi,
I'm about to install a tracker in my RR and I'm looking for some help. I need a permanent live & switched live to run it. I've taken a permanent feed from the back of the clock (red/white) and a switched feed from the plug that feeds the DSC/suspension height. I've checked via the multimeter and all checks out but still I'm unable to power the unit up. All earth's are good (off the the transmission tunnel bracket) The unit was working fine when removed from previous vehicle.
Any ideas.....?
cheers Gavin
https://www.youtube.com/@ChallengingClassics
Post #66302 30th May 2011 7:26am
stu
sorry to jump in but this seems as good a place to put this as any.
i have reccently spent a small fortune on a new caravan, i won't bore you all with the details. it came fitted with a tracker as standard.
the beauty of it is it is self powered with no wires.
i thought this may be of interest to some of you, i was thinking about getting one for the FF as well.
http://www.sure-track.co.uk/index.html Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #66320 30th May 2011 9:23am
dan_uk_1984
I'd be very careful taking feeds from any buttons or from the clock as these don't run on standard 12v they all run with in a 12v data bus. So that may be why it's not powering up.
I would suggest that somewhere in the boot would be a better idea as there are lots of feeds in there. Or behind the glove box and take a feed from the fusebox somewhere?
Post #66340 30th May 2011 12:16pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Self powered, how does that work then?
Gone - Range Rover Supercharged 2006
Post #66342 30th May 2011 12:26pm
stu
all the blurb is on the web site if you use the link. basically it has its own built in power source and is stuck down with a mega adhesive pad. there is a magnetic trip switch which activates if someone finds it and tries to remove it.
have a read of the web site and see what you think. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #66359 30th May 2011 3:41pm
JustinP
How do you keep the battery charged?
Post #66361 30th May 2011 3:46pm
johnson1
3 year battery apparently...
Post #66362 30th May 2011 4:02pm
Superspoons
Cheers Dan- I didn't realise that (still in Defender electric mode..) I'll do as you say and look in the boot. Does a wiring diagram exist at all for the 2006 model? Gavin
Post #66369 30th May 2011 4:41pm
