Home > Wheels & Tyres > Does 19" alloy rims from 3.6TDV8 2008 'll fit 4.4 TDV8
philcorsa
France 2008 Range Rover Vogue TDV8 Buckingham Blue
hello,
Everything is in the title !
thanks for your help RR L322 4.4 TDV8 Vogue
RR L322 3.6TDV8 Vogue
Disco TD5 HSE
RR P38 4.6 HSE v8 GPL
Disco 3.9 V8 GPL
Disco 3.5 V8 GPL
RR 300TDI
RR 2.4 VM TDI
Land Commando
Post #662830 26th Apr 2023 8:24am
fisha
what year is the 4.4 ?
i think its unlikely, I have in my mind that the all the 4.4 versions needed 20" minimum V8 or else ...
Post #662845 26th Apr 2023 10:58am
GraemeS
D4 19" rims fit the 4.4 but IIRC earlier 19" rims including early L322 19" rims don't fit. I have D4 19" on my MY12 4.4 TDV8 fitted with 255/60R19 GG AT3.
Post #662849 26th Apr 2023 11:12am
Balloonengineer
Other than discovery rims, 2 types of 19 inch original L322 Range Rover rims fit on a 4.4 TDV8
I have original factory 19 inch rims on my 2012 4.4 TDV8 . (one style is specified for the armoured version) The reason is the larger front brake calipers foul the inside of the rim on some designs.
So if you post pictures of your rims, you will get a more definitive answer if they fit, especially if you have big calipers.
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #662852 26th Apr 2023 12:31pm
JCW
United Kingdom 2012 Range Rover Autobiography TDV8 Sumatra Black
Style 15 is the generally recommended 19” wheel to fit later L322’s with the larger front calipers
 Jonathan
2007 Defender 90 XS Hardtop
Post #662854 26th Apr 2023 2:19pm
philcorsa
my 4.4 tdv8 is 2011 may, brembo 6 pots, my 19" rims are from my old 3.6 tdv8 year 2007
i have read some where that the old rims desn't fit because of the 6 pots brembo caliper, just want to know if somebody try... RR L322 4.4 TDV8 Vogue
Disco TD5 HSE
Disco 3.9 V8 GPL
Disco 3.5 V8 GPL
RR 300TDI
RR 2.4 VM TDI
Land Commando
Post #662855 26th Apr 2023 2:23pm
philcorsa
Disco TD5 HSE
Disco 3.9 V8 GPL
Disco 3.5 V8 GPL
RR 300TDI
RR 2.4 VM TDI
Land Commando
Post #662856 26th Apr 2023 2:26pm
JCW
Pretty sure they won’t fit in terms of clearing the calipers. Jonathan
Post #662857 26th Apr 2023 2:34pm
Balloonengineer
This 19" also fits, but sadly has no style name in the parts manual apart from 6 spoke, but might be interested in a set myself if there are any going cheap!
Best wishes
Post #662859 26th Apr 2023 2:43pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
They fit on the rear, but they don't fit on the front with the 6-pot callipers.
 The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #662864 26th Apr 2023 3:40pm
philcorsa
find these ones, 20" from L405, type 502 i think, normally 'll fit ! RR L322 4.4 TDV8 Vogue
Disco TD5 HSE
Disco 3.9 V8 GPL
Disco 3.5 V8 GPL
RR 300TDI
RR 2.4 VM TDI
Land Commando
Post #662920 27th Apr 2023 12:42pm
