![]() | Home > My Range Rover > My L322 G4 |
joncorry Member Since: 18 Dec 2018 Location: Warrington Posts: 87 ![]() ![]() ![]() |
I’ve had some new Delphi discs and pads in the boot for a little while so took advantage of the good weather yesterday. My efforts were curtailed by a solid Caliper which didn’t look too old, still wouldn’t move with a block of wood and a hammer! New ones going on today.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
I tried drilled and grooved with Fatty offroader, TBH they were about the same as stock, I did find the grooves and holes are too small to trap stones though....
Both front discs, pads and calipers refreshed, the rears are next and then some bedding in.
Fatboy Slim Member Since: 21 Aug 2021 Location: Bridgend Posts: 31 ![]() ![]() ![]() |
Cracking job! |
Got the rears changed apart from the calipers - new ones are in the post, wish I’d bought handbrake shoes but I’ll get them and do them at the same time.
This weeks job was something I’ve wanted to do since buying the G4, removing the window tints. I’m not against them, they suit a lot of Range Rovers but not this one so off they came!
One thing I forgot to note down was a bit of a grumble from the rear of the car. Sounds like a wheel bearing noise, a hum, but they’ve been changed in my ownership. It happens when the car has been driven for more than 10 mins and warmed up and seems to be only under load as opposed to all the time. It’s not getting louder but it is noticeable.
The last time I posted, there was a grumbling. Turned out to be stuff in the gearbox as I had it flushed and new filters put in, all is well again.
She’s all loaded up as we start to move bits and bobs north as part of our relocation to Cumbria. Also, there a chap that has been recommended to weld up my sills and arches and he’s taking a look at it on Saturday. Fingers crossed he’s that chap to do it!
Enjoy.... |
Another pic of her out in the wilds…took this pic as it looks like a toy/model next to the trees.
Last weekend I managed to acquire a Mantec sump/bash guard. These are hard to find and looks to be from a 2006 vehicle but I’ll make it fit with the winch.
The G4 is away to my preferred local independent for some TLC, namely refitting of the old o/s cat as it’s been welded and new 02 sensors installed.
Oh… and I fitted the sump bash plate
