Home > Maintenance & Mods (L322) > Overheating 4.4 TDV8
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
I'm at my wits end with the coolant on my MY2012 4.4 TDV8... Any help, advice is greatly appreciated.
Engine runs as it always has, smooth and quiet until the temperature gets ove 100c.
Pootling around town at 30 mph the temperature runs at around 107 to 107c. As soon as i drive up a hill the temperature rapidly rises to 155c and above and the temperature guage moves to the right close to the hight hand marker.
On the motorway on a flat stretch at around 60 mph temperature runs to around 107c, upon even the slightest accelerattion to 70 mph the temperature quickly rises to 115c plus, with the temperature guage again moving to the right of the scale. When on cruise control and the temperature reached 115 it cancels cruise control.
When I put the heater on maximum heat and the blower on maximum the temperature comes back down to around 107c at around 60 mph.
1. No coolant leaks.
2. No pressure loss (Pressure tested when cold and hot, no pressure loss or leaks).
3. After a run as describe above I have noticed that the top hose collapses when the coolant has cooled, as if a vaccum had been created in the cooling system.
4. No oil leaks or loss,
I have had the front end on ramps and have burped the top hose for days.
Has anyone had a similar experience?
Again any help will be greatly appreciated.
John 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #662053 16th Apr 2023 6:58pm
kevinp
My top hose used to collapse and needed to be replaced. I also changed the expansion tank cap. Mine didn't over heat though. Caps are only a fiver.
Post #662056 16th Apr 2023 7:45pm
fisha
The heater on max, and fans full dropping the temperature suggests that the system is able to dump heat through the heater matrix, but that its not doing that through the main radiator where it should be dumping the most of the heat in a normal manner.
Which then suggests that the hot coolant isn’t passing through the main radiator … thermostat stuck, or blocked coolant pipe.
Are the pipes running to/from the radiator hot? If you squeeze them do they feel like they are full ? V8 or else ...
Post #662058 16th Apr 2023 8:28pm
GraemeS
I would be changing the thermostat without further delay.
Post #662059 16th Apr 2023 8:40pm
JayGee
Be aware that there has been a parts shortage of thermostat housing parts for a while so check you can get the part before you remove it. The thermostat housing is part of a bigger component and can’t be purchased separately however it can be replaced without removing the whole housing which makes it an easier job but still requires quite a bit of work removing fan and belts etc. I wouldn’t drive it in this condition either. 2012 TDV8 Vogue (L322)
Post #662076 17th Apr 2023 4:13am
4434Morrison
Many thanks to all for the advice...
Comments noted. I did purchase a new thermostat from Rob at Duckworths a couple of weeks ago so its time to fit that.
Whilst doing so I will drain the cooling system via the bottom hose, hopefully its only the thermostat. Belts and rollers were all done about 6 months ago. and the waterpump is not leaking, so don't expect any issues with those components. I just wish I had replaced the thermostat at the same time.
Will report back if the thermostat replacement solves the overheating issue.
Again, thank you all for your input.
Post #662079 17th Apr 2023 8:30am
GraemeS
I'm another who didn't think to change the thermostat when changing the pulleys and belts. I did change the water pump though.
Post #662091 17th Apr 2023 10:08am
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
I would check belt tensions as well to ensure water pump is being driven ok. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #662102 17th Apr 2023 12:28pm
4434Morrison
THank you for the advice...
The tensioner was replaced with the rest of the rollers.. Smile
Now waiting for some decent weather here in the South East as will be working on the drive... Looking at the weather forecast ists going to be rain, wind and low temperatures for the next week.
Post #662112 17th Apr 2023 2:58pm
Broadley RR
Hi,
How did you get on with this issue, I’m experiencing exactly the same thing to my 2011 4.4 TDV8 - could you let me know how you rectified the issue?
It would really save me a lot of time and money
Many thanks in advance for your input
Lee
Post #683389 21st Jan 2024 9:08am
4434Morrison
I changed the thermostat. The issue was the thermostat sticking closed. I had ordered a complete thermostat replacement from Duckworths, but these parts were on back order with no anticipated delivery date.
I was able to order the thermostat internals and disassemble the existing thermostat housing then replace the internals.
Undo the cooling fan assemby and turn the fan to the right.... Mine came off without needing to hold the shaft. A gentle tap with a hammer shocked it loose... I suppose it depends on who put it back on... no need to over tighten it. You can then move the fan towards the radiator suficciently to geive you enough rook to remove the thermostat housing.
There is a major design flaw with the plasitic thermostat housing in that the plastic tabs that hold the internal metal thermostat in place are likely to be very brittle and unless the old internals are removed and replaced very carefully, then these plastic tabls will break off and render the plastc thermostat housing unusable.
When you get the thermostat enclosure off take the enclosure to the tailgate. then find a suitable Find a large round piece of pipe, that fits over the metal thermostat internals, but between the two plastic lugs.
Then with the bottom of the thermostat housing on the tailgate use one hand to steady the housing and the other hand combined with your body weight to push the thermostat spring down and simultaneously twist the two metal lugs on the thermostat out from under the two plastic lugs of the housing, without stressing the plastic lugs. Needs quite a lot of pressure. The secret is to find a correct circular item that will fit over the top of the thermostat and not interfere with or stress the lugs.
When removing the old thermostat internals and replacing with new there is a special tool available to ensure that the pressure on the plastic tabs is managed and they are not damaged. Alternatively
You do not have to disassemble the radiator shroud as per the workshop manual. Instead, get the car up on rampts, remove the under tray and remove one of the two bolts holding the metal coolant pipe in place and slacken the second bolt off slightly. Then unbolt the thermostat housing and you will have enough wriggle room to remover the housing. Then you can either replace the thermostat internals as described above or the complete housing if you can get one.
If you do damage the thermostat housing tabs without a replacement housing being available then you can run the car without a thermostat, which should only be a short tern solution until you can get a replacement housing.....
Hope this helps...
Post #683394 21st Jan 2024 10:19am
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
running without thermostat will overheat engine! You need blanking plate, to close short circuit.
Post #683419 21st Jan 2024 12:47pm
JayGee
My leaking thermostat
Caused low coolant temps and long warmup times as too much flow went through the rad. It drove perfectly well so I would assume no Thermostat woukld do the same but worse. I'd order both upper and lower mixing box / thermostat housing parts as the plastic will be so brittle now with age you can easly break something trying to extract the screws. 2012 TDV8 Vogue (L322)
Post #683427 21st Jan 2024 1:14pm
jimmie
No will not. Even damaged yhermostat if opens to radiator will restrict flow in short circuit. If you remove then water will flow where lower restriction is,so will go mostly back to the engin rather than long way through radiator.
Post #683443 21st Jan 2024 5:38pm
neilly
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Jsut a quick thread revival here,
Using a GAP IID , What is the std coolant temp reading if the ambient temp is at 20C? Temp reading at when engine is up to normal temp & running at motorway speeds.
I would like to know for any future issues / questions, I have plugged the GAP in and it seems to be 96C up to 99C with AC on and if I turn the temp dials to max and high fan speed it can drop to 94C ish.
Thanks fro any info.
Cheers
Post #693037 20th May 2024 5:13pm
