Home > Technical (L322) > ZF6hp28 2-3 Flare |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
That’s disappointing. It should report solenoid current, in Amps, with a minimum value around 0.05A and a maximum of 0.85A
29th Mar 2023 8:38am |
I assume those charge pressure units are actually mbar, and not kPa, as otherwise they’re a factor of 10 out. If they are in mbar then, predictably, only the E-clutch is outside the recommended limit (+/- 300mbar). I say predictably because of the known issue with rear stator bush wear.
5th Apr 2023 10:20pm |
jjfang Member Since: 13 Nov 2020 Location: Chicago Posts: 44 |
So the GAP tool is saying this is kPa, and its worth noting, this is after the 2nd unit that was rebuilt |
5th Apr 2023 11:39pm |
I suspect that the IIDTool is incorrectly displaying kPa as the unit, but it is displaying the correct value (in mbar).
6th Apr 2023 10:39am |
Yeah, at this point I've done about 3,000 miles on the unit with half the driving in downtown Chicago and half the driving on highways for long trip. I can track shift time but they seem off/not correct.
6th Apr 2023 1:05pm |
Yes, unfortunately people have reported in the past that the IIDTool just doesn't seem to be able to report the solenoid adaptions correctly :
7th Apr 2023 10:19am |
p739 Member Since: 15 Apr 2023 Location: Ontario Posts: 2 |
Not sure if this helps.
16th Apr 2023 1:02am |
I have found with my gap tool that sometimes it does not show values correctly. It seems to be less of an issue if the tool is plugged in with the truck off and then started before initializing the blue tooth connection. Has anyone else noticed this? |
17th Apr 2023 3:24pm |
Av8or Member Since: 29 Apr 2023 Location: Newnan, Georgia Posts: 4 |
Does anybody have or know where to find a diagram for the upper half of the valve body. I have the zf6hp28 transmission. I’m putting in the sonnax zip kit and thought I had checked and double checked the location of all the check valves and balls. I missed one and now have to figure out where it goes. Any help much appreciated. I took pictures but they didn’t capture enough detail.
29th Apr 2023 11:26pm |
Here you go
30th Apr 2023 11:47am |
Phil…thank you very much. You just saved my Sunday afternoon. I was prepared to go on a deep dive on the internet. Your diagram confirmed a spot I had marked as a possibility from my pictures but I wasn’t going to put it back together without better information. Thank you sir.
30th Apr 2023 5:50pm |
Having now gone through the 6HP28 Mechatronic unit in some detail, it’s clear that it is completely different to the 6HP26 unit. The solenoids are numbered in the same order : but activate different clutches :
I’ve reproduced ZF’s logic table for the 6HP26 : for the 6HP28 : What concerns me is that there’s no recognition of this difference in the Workshop Manual, where information for the Mechatronic unit from the 6HP26 is simply copied and pasted as a job lot to the 6HP28. The main difference between the two transmissions (i.e. Generation 1 vs Generation 2) is the much faster response times and shift dynamics (50% improvement) that came about directly as a result of these Mechatronic changes. Hopefully the diagnostic tools get it right when they’re reporting on the status of the solenoids for the 5.0 litre L322 models? Phil |
12th Jun 2023 11:41pm |
I've asked GAP before and they are saying that they are just pulling what ever is being communicated from the computers. From my perspective, I don't think many of the value are correct for the zf6hp28. I've spoken with a decent amount of builder and their perspective is given the amount of work and the fact that the trans was rebuilt twice and has a rebuilt valve body too now. I've been told to just drive it and not worry then. Not saying that idea thrills me but its not too bad, its honestly at times just 20-50 rpm max and its very intermittent. |
16th Jun 2023 10:16pm |
Yeah at this point I'm at a loss.
27th Jul 2023 1:17am |
