Home > Technical (L405) > Sourcing a new gearbox earth strap
Max94L405
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Hi all,
I’m struggling finding a new replacement gearbox to chassis earth for my l405.
I’ve fitted a standard battery cable replacement but it’s not ideal as it’s so close to the rear prop shaft. The old one has tabbed style fixing so it can’t turn once tightened down and work its way loose.
I’ll attach a photo of the old one.
I’ve tried searching the part numbers on the label but hasn’t gotten me anywhere.
Kind regards,
Post #661513 10th Apr 2023 4:04pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
The number on the label is what is known as the "Engineering part no." and if you have access to JLR's online parts catalogue can usually be referenced back to a stock number.
LR040627 is the stock number for this cable, retail cost is just short of £50 Shocked
Post #661589 11th Apr 2023 12:01pm
