Home > Maintenance & Mods (L405) > Split/Cracked lower tailgate... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
Just went outside to have a look at possible rust following Gremlin500's post
10th Apr 2023 12:05pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1417 |
That little rose-joint needs sorting too, those have zero protection and rust horribly. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
10th Apr 2023 12:18pm |
The split is not due to someone overtightening it, it flexis every time it's used and mine has split the alloy...
10th Apr 2023 12:46pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
Mine’s looking ok, but I’m wondering if it’s worth a large washer to help spread the load?
10th Apr 2023 5:18pm |
Doesn't look like there is any plate behind it, lean in and press the close button and see how much it flexes...
10th Apr 2023 6:28pm |
Yup, just had a play in the slinging rain at the end of a dog walk and I think I can see a little bit of a flex couldn’t make my mind up if it was flexing or I was thinking about it that much I’m seeing things!
10th Apr 2023 6:53pm |
I've done this as a temp repair, stainless washers and a replacement stainless flange head bolt... When it gets warmer I'll play some more...!!
11th Apr 2023 10:48am |
sass Member Since: 23 Apr 2014 Location: Helsinki Posts: 30 |
Just fixed mine this weekend.
11th Nov 2024 11:35am |
