Home > Technical (L322) > Inlet manifold
Page 3 of 3 <123
pcourtney
well done - ditto re the write up, I have a feeling many of us will be doing this one day Sad
Post #661344 8th Apr 2023 12:00pm
Rudyard1
So all is not well - felt a weep of oil coming from the rear of the inlet manifold. Tightened up all the bolts again and then road test - still weeping. Tightened up the bolts at the rear and then one of them sheared.
I really hate this car…….
Anybody know a good garage around Leicester/Loughborough area? 2007 Range Rover Vogue 3.6 TDV8
Post #661449 9th Apr 2023 8:24pm
TDV8 Paul
Sounds like you might have kinked the seal as you put the cover back, easily done on the rear studs as it’s a bit tight 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #661454 9th Apr 2023 11:57pm
Page 3 of 3 <123
